Author Topic: GQ1 Rear Axle - Standard Ratio?  (Read 29527 times)
Offline 81Cheyenne
« on: September 01, 2007, 10:06:53 am »
Does anybody know what the actual ratio is of this rear end?
Re: GQ1 Rear Axle - Standard Ratio?
« Reply #1 on: September 01, 2007, 02:15:53 pm »
I thought GQ1 meant regular open differential but I could be wrong. Any other codes? If not you 'll need to pop the cover off to find out.
Offline 81Cheyenne
« Reply #2 on: September 01, 2007, 02:50:33 pm »
Nope.  No other codes.  At least not on the glove box sticker.  All it says is: "GQ1 - Rear Axle - Standard".
How do I determine the ratio after pulling the cover?
thanks.
« Reply #3 on: September 01, 2007, 03:26:49 pm »
You sent me a PM on doors, your mailbox is full and your e-mail is hidden.  Contact me via my e-mail in my profile.
« Reply #4 on: September 01, 2007, 03:28:37 pm »
thanks.
You will see 2 numbers on the outside of the ring gear, divide them and that is what you have. IE 43/13 3.31
Offline 81Cheyenne
« Reply #5 on: September 01, 2007, 03:42:58 pm »
Thanks Zeig.
Looks like your box is full too.  I emptied mine but in case it doesn't work:
psdisme@hotmail.com
thanks!
« Reply #6 on: September 01, 2007, 03:54:52 pm »
Thanks Zeig.
psdisme@hotmail.com
thanks!
Sent you an e-mail and PM.  I guess 1 message and it is full???
Offline 81Cheyenne
« Reply #7 on: September 02, 2007, 07:38:52 am »
Got your email.  Looks like 1 message fills up the box.
Offline 81Cheyenne
« Reply #8 on: September 03, 2007, 03:11:18 pm »
Ok, I followed a link to a site that has reprints of the original Chevy truck flyers. Looks like the standard ratio axle for a C10 in 1981 is 2.73.  Does that sound about right?
« Last Edit: September 03, 2007, 03:14:52 pm by 81Cheyenne »
« Reply #9 on: September 03, 2007, 07:17:42 pm »
Is it a 10 or 12 bolt? Most of the 12 bolts were 2.73 or 3.07. The 10 bolts were usually 3.08 or 3.42
Offline 81Cheyenne
« Reply #10 on: September 04, 2007, 10:01:16 am »
It's a 10 bolt.  Hey, do you think that a 10 bolt will be strong enough for a slide in or pull behind camper?
« Reply #11 on: September 04, 2007, 04:59:43 pm »
You should be ok if you don't exceed the GCVW rating.  I suspect with the leaf stack in your other post you have the lighter duty braking with the thinner rotors.  Beefing up the springs doesn't change the rest just that it will handle the load better.  I used to tow my car trailer with my old 82 with a worn out 305 and 3.08 rear end.  It didn't do to bad.
