Author Topic: Oil Pressure  (Read 3909 times)
Offline dtr118
Oil Pressure
« on: September 16, 2007, 09:28:30 am »
I have a 77 GMC stepside 2wd, I swapped the 350 with a 327.  I got the engine to start yesterday but I do not register any oil pressure.  I bought a new oil pressure switch and installed it, still no pressure. I pulled the valve cover off while it was running and there was oil in the valves.  This truck has been sitting in my garage for about 10 years.  Is there a chance the gage went bad?  Is there another way I can check for Oil pressure?...thanks  This is my first engine install, so I am just learning as I go.
Greg
Re: Oil Pressure
« Reply #1 on: September 16, 2007, 10:21:12 am »
get a mechanical pressure guage and hook it up under the hood and check it.  Was the factory guage working before?
Offline dtr118
Re: Oil Pressure
« Reply #2 on: September 16, 2007, 12:29:11 pm »
Thanks for the response. The gauge worked fine before, Where do I hook up the mechanical gauge to? and what kind of a gauge do I use?...thanks
Offline Toolmaster
Re: Oil Pressure
« Reply #3 on: September 16, 2007, 01:13:13 pm »
You can pick up a mechanical gauge at any autoparts store.   Get a cheep one you can stick back in your tool box. (use it as a tool)
Hook it up where the pressure switch is plumbed in.
When you remove the switch check for any blockage in the block, use a flashlight and look into the hole.
Make sure no sealer is in the switch, hole inside should be clear of foreign matter.
« Last Edit: September 16, 2007, 01:15:23 pm by Toolmaster »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Oil Pressure
« Reply #4 on: September 17, 2007, 03:10:38 pm »
You can always check your pump by putting on a new oil filter.  Turn the engine.  See if oil filter fills w/ oil.   Foolproof way to see if oil pump works when putting in a new engine.
