Author Topic: Thermostats?  (Read 18164 times)
Offline 197
Thermostats?
« on: September 23, 2007, 07:01:24 pm »
I changed my thermostat in my 454 from a 195F to a 180F. Because It would get kinda hot.
I herd that I will get worse gas mileage with the 180F and less power. Is that true?
'73 C20 454
Offline jays2w87
  • Bone stock..... Not for long!
Re: Thermostats?
« Reply #1 on: September 23, 2007, 07:46:20 pm »
I would wait for one of the bigger guys to answer you but, That sounds crazy, And if its true its measured in a lab. Nothing you would ever notice.
Again, see what someone else says but, I have done a few motors and never heard of that.
As far as power, well if the engine is cooler its going to run more efficient. I had a small block ford motor a while back and it seemed like when it was up to temp for a while it didnt move quite as good as when it ran cooler. No Fuel issues though.
I have to be honest, If your running a big block does gas even matter ?
My last 4 wheeler I ran 38 inch tires and everyone asked about gas milage. My answer was ... I have no clue. I put gas in it when its empty, then I drive til its gone .
Offline 197
Re: Thermostats?
« Reply #2 on: September 23, 2007, 08:02:47 pm »
Ya, I have owned the truck for about 3 years and havent figured the mileage out yet.  ;D
'73 C20 454
Re: Thermostats?
« Reply #3 on: September 23, 2007, 08:07:35 pm »
The 195° Tstat brings your engine closer to optimal temperatures. An engine running cooler loses more heat energy from the heat of combustion to the cooling system. So in a sense you are wasting thermal energy. Since you have a HEAT engine you are wasting that heat energy. Most modern engines run 205°-220° before the cooling fan is energized. On the flip side cooler cylinder head temps reduce the risk of detonation. But if your engine isn't overheating or detonating then stick with the stock Tsat. If you do a lot of towing and heavy romping around keep the 180°
Offline 197
Re: Thermostats?
« Reply #4 on: September 23, 2007, 08:16:35 pm »
So the 195 would be better? Its a daily driver.
It was dieseling when I would turn it off. And it would get a little hot when It was just idling at lights so I changed the thermostat and I have been running 93octane. And its stopped dieseling dont know if it was the gas or the thermostat.
'73 C20 454
Offline jays2w87
Re: Thermostats?
« Reply #5 on: September 25, 2007, 07:16:55 pm »
I would say Fuel issue. Try running some cleaner thru. My resolution is 15 gallons of gas, 2 stp treatments (same time) Along with either hi test fuel or a bottle of octane booster. The combo of 3 works awesome !
You will nitice a difference once you burn thru that mixture. While burnin thru it it runs fine . You wont notice anything.
If you look on the shelf you'll see big doller treatments, Dont Buy them. They are all the same. I have experimented with my car , my wifes, a few others I have owned, the best result is the 1st thing I explained. I usually do it once a year. I'm over here in the north side of CT almost in Mass. We get snow and crap weather so I do it going into the winter. Gets all the crap out of my fuel prior to freezing weather.
Offline 197
Re: Thermostats?
« Reply #6 on: September 25, 2007, 07:22:44 pm »
Ok, thanks for the tip!
'73 C20 454
Offline 75 C20
Re: Thermostats?
« Reply #7 on: September 25, 2007, 09:12:30 pm »
you might want to check your timing
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: Thermostats?
« Reply #8 on: September 26, 2007, 02:38:24 pm »
For dieseling check your timing, make sure your choke is working, do a top engine cleaning and then change your oil.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Thermostats?
« Reply #9 on: September 26, 2007, 07:20:47 pm »
If it is dieseling real badly, I'd go ahead and retard the timing just a tad.  (Turn distributor clockwise a hair).  See if that stops the run-on after turning the engine off.
Another option is to go with a cooler spark plug.  It seems as though the heat in combustion chamber detonates (without spark--ignition off) the fuel left over.  It is kind of embarrassing---turn the key 1/2 off while the truck is still in DRIVE.
Offline 197
Re: Thermostats?
« Reply #10 on: September 26, 2007, 07:55:55 pm »
It stopped dieseling after the change to 93 octane. Why would that cause it?
'73 C20 454
Re: Thermostats?
« Reply #11 on: September 26, 2007, 09:28:25 pm »
Becaue higher octane fuel is less combustible at lower temperatures so it doesn't ignite as easily. Putting in 93 is fixing the symptom not the problem.
Offline 197
Re: Thermostats?
« Reply #12 on: September 26, 2007, 09:35:59 pm »
So the problem is the timing? Correct?
'73 C20 454
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Thermostats?
« Reply #13 on: September 27, 2007, 11:11:28 am »
Could be.  It's just an idea.  Doesn't hurt to try it.   When driving uphill or under a load, does the engine seem to "rattle" some from the valves?  Having 93 octane will disguise this somewhat.  To test this, I'd use 87 octane.  If it rattles some, I'd do as mentioned, retard the timing some.
Quote
You mentioned that at idle, it tends to get hot or overheat?  I'd check your clutch fan (if that is what you have) or flush the radiator.  How old is your water pump?  If your cooling system is not decipating the heat correctly, it will remain in the engine and contribute to diesling due to the heat.
« Last Edit: September 27, 2007, 11:15:27 am by SgtDel »
Re: Thermostats?
« Reply #14 on: September 27, 2007, 11:34:15 am »
Do you know where your timing is set right now?
