Performance
383 kits
Topic: 383 kits (Read 11215 times)
75 C20
383 kits
October 07, 2007, 09:19:09 pm »
im looking at starting to build to high preformance 383. i am looking at getting a eagle bottom end 383 kit. on summit it as about valve reliefs - i could get 2, 4 or none- what should i go for- im am going to be putting edelbrock heads and intake on it when its done - heres the edelbrock top end im probly gonna get
http://www.sdparts.com/product/E2096/PowerPackageTopEndKitSBChevy383460HPETecHydRollerCam198799Blocks.aspx
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 383 kits
October 07, 2007, 10:37:05 pm »
That depends. What do you want to have for a compression ratio? The valve reliefs will allow you to have proper clearance when you opt for different cams. If you want to bump up the CR then skip them. 4 valve reliefs allows a better balanced piston.
75 C20
Re: 383 kits
October 08, 2007, 08:29:00 pm »
hhmm....- what do you think would be the best. im lookin to get as many ponies out of this engine as possilbe
but i want a good running well balnced engine
Re: 383 kits
October 09, 2007, 07:29:29 pm »
Then chose either the flat top or 4 valve releifs. As far as your compression ratio you need to consider the heads, fuel octane and timing. Higher c/r will give you more power but it's not free and there's lots to consider.... For a 383 your rev's will be lower, you'll see an increase in torque but what are you trying to build? A screamer or towing machine? Are you sure a 383 is what you want?
75 C20
Re: 383 kits
October 09, 2007, 08:14:42 pm »
well i kno 383 s are more of towing machines- but im kinda llokin to build somewhat of a screamer- now im kinda just leanin towards buildin a wild 350
heck now i dont kno just what exactly i want
Re: 383 kits
October 09, 2007, 08:55:03 pm »
You can really trick out a 350 at really good prices and get excellent results. If you're opting for more torque from a gasser then a 383 or better yet a 400 is your best bet unless you are ready to step into the big dogs and go big block power. I can tell you owning a bigblock vs small block is very different but big blocks cost more coin to build and use more fuel. So I suggest you layout your driveline on paper and decide what you want and when you want it and how much $ you want to spend.
75 C20
Re: 383 kits
October 09, 2007, 09:05:42 pm »
i might just make a wild 350- just gotta figure out how much money i need to save up.
i cant afford to get a bigblock- its not the gas that is it but the massive price on jsut getting ahold of one and like said- 350s can be built with less expensive.
Last Edit: October 09, 2007, 09:07:19 pm by 75 C20
75 C20
Re: 383 kits
October 17, 2007, 08:41:51 pm »
i've been lookin around and what kind of ideas you guys have for bottom ends-the whole rotating assembly- crank pistons....
im amd finding a lot of 2 piece rear main seal ones- since my block -a 95- is one piece i have to get a 1 piece crank to go back right? o will a 2 piece rear main seal rank work?
im looking to get about 450 hp out of this build
im probly going with a edelbrock top end power package
it will be a 355 im thinkin now so give me ne ideas you have for bottom ends
Re: 383 kits
October 18, 2007, 05:19:20 pm »
What's wrong with the crank you already have? A machine shop can regrind it for under a hundred bucks. When you get new pistons have them pop them on and balance them for you and save $$. If $ is no object then buy a rotating and reciprocating assembly from Summit. And no the one piece vs 2 piece are not interchangable. The one piece has no conterweight on the back.
the383
Re: 383 kits
October 21, 2007, 10:25:41 pm »
You can check out flatlanderracing .com and check out their stroker kits , they offer alot , also alot of people seem to prefer scat rotating assemblies (better quality control). A few things to consider about the eldebrock top end package , if your block has a roller cam other cam companies have reasonably priced roller cams and lifters that are light years ahead ,and as far as heads AFR are the top of everybodies list but a little pricey. Brodix I/K 180 and 200's are great for a little over a grand and Canfields are nice to. I just think for the money your are going to spend on the eldebrock package you could put together a more powerful package for the same money. If I have hurt anybodies feelings I'm sorry thats just my opinion .
Last Edit: October 21, 2007, 10:28:35 pm by the383
Leadfoot
Re: 383 kits
October 24, 2007, 07:24:26 am »
if you want to make one of these trucks run,you just can't beat a big block
Performance
383 kits
