Author Topic: 4" lift???  (Read 12086 times)
Offline 75??? franken-trunk
4" lift???
« on: October 08, 2007, 07:34:01 am »
 :-\ i want to do a lift to fit 35's" for mudding will i need to lengthen my drive shafts, brakelines, would my half ton axles handle the mudding, will a 2" inch lift fit 35's"? any info will help thax ;)
Jack'em High
Fat chicks can't climb
Re: 4" lift???
« Reply #1 on: October 08, 2007, 10:17:15 pm »
No you will need 4" to fit 35"s as far as your 1/2 ton being able to handle mudding well that depends on how bad you beat the crap out of it. You will need drop brackets for the front brake lines/hoses, longer shocks, a steering arm would be good, you can drop your transfer case down 1" and you're driveshafts should be fine. If you go 6" you will definitely need to not only pitch the rear axle but have your driveshafts sent out.
Re: 4" lift???
« Reply #2 on: October 09, 2007, 12:53:51 am »
i planed on getting the arm and how big of a deal is the transfer case drop i have a shoe string bugget and how hard are they to do? oh and does any one know of a 4" easy ride kit and price i like a soft ride my self?
Jack'em High
Re: 4" lift???
« Reply #3 on: October 09, 2007, 08:34:42 am »
The transfercase crossmember bolts have spacers on them above the frame. I usually just place them between the frame and the crossmember.
http://www.4wheelparts.com/PDT2226.aspx
or check ebay sometimes there's good deals but they'll whack you on the shipping
Offline KojaK 79k10
Re: 4" lift???
« Reply #4 on: October 10, 2007, 07:59:42 pm »
4" will clear 35's but 6" will clear better with no clearance issues at all. i don't recommend the transfercase drop because it puts strain on your transmission because your only dropping the rear. if you go 6" you can just make up for it in the longer drivelines. I have 6" lift on my 79' and it does great in mud, that little extra clearance is nice in mud and water crossings. I payed under 1k w/out wheels and tires. as for soft ride systems, with a solid axle you'll ride rough with or without a lift. i would only go full spring lift if your worried about a smooth ride. add-a-leafs and blocks only make your ride worse
77 Chevy swb "race truck"
*SOLD* 79' k10 Silverado SWB "Kojak"
truck is gone but not forgotten, worst thing I ever did was sell this truck and I regret it everyday.
Re: 4" lift???
« Reply #5 on: October 12, 2007, 01:46:01 am »
i was thinking of doing some fender triming to clear the tires i want to keep the cg low dew to the fact that i drive a ton delivering pizzas and on the bugget i cant lengthing my drive shafts what do you think??? would that give me the clearence i need?
Jack'em High
Re: 4" lift???
« Reply #6 on: October 12, 2007, 10:02:52 am »
You can definitely cut the fenders to make room for them, but you are going to be cutting alot if you don't lift it.
Offline KojaK 79k10
Re: 4" lift???
« Reply #7 on: October 13, 2007, 09:03:54 pm »
you can get information from lift kit manufactures to see about driveline modifications. this is not every kit but i have seen quite a few 4" lift kits that require NO driveshaft mods. you cannot fit 35" tires with no lift no matter how much fender trimming. with a 4" and trimming you could have 35's and still keep the pizza delivery functionality and still look good.
Offline 1976Scottsdale
Re: 4" lift???
« Reply #8 on: October 14, 2007, 07:50:42 pm »
The last 4" kit I installed cleared 36" tires without rubbing.  The kit came from Jegs and was an EZ-Ride type.  I payed 325 or so for the kit and it came with just about everything.  I opted to spend the extra 90 bucks for longer breaklines as mine stretched a bit in turns.  There wre no driveline mods required at all and I would reccomend the transfer case drop if you can find one.  The rubber motor mounts will keep everything from binding or snapping.  I was in your shoes... no money and tires that did not fit.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: 4" lift???
« Reply #9 on: October 23, 2007, 11:32:17 pm »
The transfer case drop kit is not going to strain your transmission. The engine, tranny, and tcase all pivot as one unit on the motor mounts. If you go any higher than a 4 inch lift you have to drop your tcase or you will eat through ujoints like crazy. If you are really on a tight budget just do a shackle flip kit in the rear and either re-arch your front springs or buy new lifted front springs to match the rear. (Usually about 1 inch higher unless you want a rake job). Shocks are a must and brake lines and sway bars must be addressed with anything over 4 inches, as well a drop pitman arm. A 4 inch lift with 35s are still going to rub and need some clearancing. A 6 will clear no problem but then you have to lengthen your drive line.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
