Author Topic: Hei Distributor  (Read 3724 times)
Offline treny
    • 83C10
Hei Distributor
« on: October 23, 2007, 04:18:21 am »
I just installed a 350 in my c-10 it wont start I put the wires on it from under the cap to the connector on outside of casting, There is also another connector where the wires from inside go it says on that that its for a tach and bat am I supose to attach  a 12 volt connection from ign sw to this plugin. Vacumns are all ok Checked them yesterday .Treny
Hii There , Stating another project , an 83 c10 2wd  .Frame etc is all good and have to replace dash pad and seat , some body work and Paint Prob flat blk wth a clear cote to seal it.Ill keep in touch with updates ..Bruce
Offline 123 pugsy
Re: Hei Distributor
« Reply #1 on: October 23, 2007, 04:32:17 am »
12 volts to the BAT only.
Pugsy
76 C10 LWB
TPI 350
Offline treny
    • 83C10
Re: Hei Distributor
« Reply #2 on: October 23, 2007, 04:38:09 am »
Thanks ,thaught iy may be that but m didnt want to burn sompthin up by mistake haha
Re: Hei Distributor
« Reply #3 on: October 23, 2007, 08:30:27 am »
You probably know this, but by BAT pugsy means switched battery power.  You should be able to find a switched power source you can plug in at the fuse panel.
Offline treny
    • 83C10
Re: Hei Distributor
« Reply #4 on: October 23, 2007, 01:11:49 pm »
haha I went right out and put the 12 volts to it and it wouldnt even shut down with the key , Story of my life eh! Found a wire that goes off with the key Guess that will work but raining out now Ill wait till rain stops . Thanks for the help guys all within a couple hrs .Now got transmission lines driveshaft etc The fun stuff .
