Body, Glass & Paint
Thank You Blazin
Topic: Thank You Blazin (Read 5214 times)
JJSZABO
Thank You Blazin
October 24, 2007, 07:32:57 pm »
I read in one of your older messages to add a little polyester resin to my final layer of body filler and I'll get a VERY smooth finish that will fill pinholes and such.........I tried it and all I can say is WOW!!!!
I use to fight with the filler to get a real smooth finish but now I can get it super smooth with this method. THANKS!!
Quick question - can I lay down epoxy after sanding to 180 grit or should I go one step further to 320 grit. Will the epoxy and surfacer fill 180 sand scratches?
Thanks again,
Jeff
Jeff
86 Chevy C-10
350, TH400
loudnlow87
Re: Thank You Blazin
October 24, 2007, 08:34:31 pm »
it depends on how many coats and mainly what the build capabilities of the primer are, but most likely it would be ok. on the other hand, why not give it a once-over with 220 or 320 just for the assurance?
stock really sucks
JJSZABO
October 24, 2007, 08:53:33 pm »
Ya - that's what I'll do - just being lazy. I'll hit it with 320 grit before epoxy.
Jeff
86 Chevy C-10
350, TH400
Blazin
Blazin new trails!
October 25, 2007, 07:31:14 am »
On a daily driver type rig I stop at 180 grit, but I also use a high build urethane primer, and sometimes cover it with epoxy. For a show finish I would go the extra step and 220 grit the surface.
Glad the tip worked out.
Body, Glass & Paint
Thank You Blazin
