Which is the outlet line on the transmission?
Topic: Which is the outlet line on the transmission? (Read 4132 times)
team39763
November 05, 2007, 06:41:51 pm »
I'm setting up an external filter and cooler for my TH350, and I need to know which is the outlet line...top or bottom(on trans)? Also, if ya'll would happen to know what size fittings are used for the trans coolant lines(on the trans)? Thanks.
Re: Which is the outlet line on the transmission?
November 05, 2007, 08:17:30 pm »
http://www.bmtrans.ca/FAQ's.htm
⌠ŻŻŻŻŻ' [☼===☼]
team39763
November 05, 2007, 09:25:22 pm »
Thanks Vile.
DnStClr
November 10, 2007, 08:32:02 pm »
Here's another link- with fitting sizes.
http://www.tciauto.com/Products/TechInfo/cooler_fittings.asp
One way to determine npt fitting sizes- measure across the threads and then subtract 1/4 " and you have the size of the pipe or fitting.
Last Edit: November 10, 2007, 08:37:28 pm by DnStClr
Don
87 Chevy Silverado
