Author Topic: 1985 Hydralic Clutch res.  (Read 16277 times)
Offline cubicdollars
« on: November 08, 2007, 07:06:18 pm »
I need a little help. I removed my Hyd Clutch res and I cant remember exactly where it gets placed on the firewall can some one please send me some picts? And some photos of a BBC Airconditioning bracket would help me out as well
Thanks
Re: 1985 Hydralic Clutch res.
« Reply #1 on: November 08, 2007, 09:29:44 pm »
The reservior bolts to the booster mount.
What year/series BBC brackets are you looking for?  An 85 1/2T didn't come with a 454?
« Reply #2 on: November 09, 2007, 03:11:09 pm »
85 chevy 1 ton 2 wd with 454 and Manual 4 speed tranny. A couple of years go I installed a set of 396 heads  and for some reason I cut the bracket up to make some other things work but now I am reinstalling AC back into the truck
« Reply #3 on: November 09, 2007, 06:26:24 pm »
I will take some pics of my 85 tomorrow and send them to your e-mail
« Reply #4 on: November 09, 2007, 09:59:02 pm »
Awsome Thanks
« Reply #5 on: November 10, 2007, 10:13:18 am »
Can't you post them here for others to see?
« Reply #6 on: November 10, 2007, 04:53:33 pm »
Here's the clutch on my 85
« Reply #7 on: November 10, 2007, 04:59:55 pm »
AC pics,  real crowded with the dual airpumps and everything connected as it came out of the factory this way.
« Reply #8 on: November 10, 2007, 05:03:07 pm »
I figured how to do it.  My KB #'s on my pics show higher than 128 but obviously OK here.  Lookout now,...
« Reply #9 on: November 10, 2007, 05:05:25 pm »
Great Thanks
the Res looks like mine but I must of had a different style compressor and my air pump was located under my Alt.
I really appreaciate you taking the time to take photo's
Thanks
Dan
« Reply #10 on: November 10, 2007, 05:07:10 pm »
What size engine is that? I cant tell if its a BBC or SBC
« Reply #11 on: November 10, 2007, 05:14:54 pm »
7.4L, the big boy.  That is the emission set up for the 8600GVW trucks in 85 with that engine and a stick.  It is very crowded under the hood.
« Reply #12 on: November 10, 2007, 06:07:50 pm »
Mine had a factory 454(7.4) as well. it a 1985 1 ton dually 2wd crew cab camper special. But my smog pump was origanaly located under the Alt. when I bought the truck I had all of the AC installed but shortly after I bought it I changed the factory Peanut port heads to a set of closed chamber 396 heads. But for some reason I decided to take the compressor off and I then modified the factory AC bracket ( what a dumb aXX)
I stripped the truck to the frame this summer, I installed bel tech drop spindles 4" in front and 4" in back. The engine was removed from my stepside it's a 454 bored .030 with pop up pistons and a rebuilt set of 781 casting heads, Should be around 10.0 to 1 check out my webshots website to see my progress.
« Reply #13 on: November 10, 2007, 06:46:13 pm »
1 tons have different emission numbers that are required by the feds, probably why you only have the one smog pump.  Was yours always a stick?  That makes a difference as well.  Sounds like a neat project.  If you need any other pictures just holler out.  I will eventually make mine like new.  Got too many other projects that come first.  Have a great day.
« Reply #14 on: November 11, 2007, 07:50:16 am »
Yes mine was a factory 4 speed and 4.56 gears :) the engine had never been out until I bought it . Since I have been a kid I always wanted a lowered dually. It's still functional I will be using it to pull my car trailer with my 77 stepside on that to the racetrack.
