Author Topic: Homemade Headers  (Read 188423 times)
Offline werewolfx13
Re: Homemade Headers
« Reply #120 on: January 13, 2008, 06:04:04 pm »
Nice, good to see all that patience has paid off. Do you mark the increased economy more to the headers or to fixing that fuel line?
Chris
'83 Chevy c10 Silverado SWB
Offline 123 pugsy
« Reply #121 on: January 13, 2008, 06:13:46 pm »
I'd say more to the headers and the dual cats/exhaust. I discovered that I had one 5 liter cat on the single exhaust. I believe that was causing the most choking in the exhaust system.
When I cut off the piece of  pinched return line , I discovered that it wasn't closed all the way as it appeared. I could easily blow thru it.
Pugsy
76 C10 LWB
TPI 350
Offline JJSZABO
« Reply #122 on: January 13, 2008, 07:00:42 pm »
Congratulations pugsy
20MPG  Not toooo shabby :)
Jeff
86 Chevy C-10
350, TH400
Offline 85MudMonster
« Reply #123 on: January 15, 2008, 09:27:08 am »
20 MPG!!!  :o :o
Oh, man! I wish I could get that....I'm jealous now....
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
« Reply #124 on: January 15, 2008, 10:08:14 am »
Great! Did you get your headers coated?
Offline 123 pugsy
« Reply #125 on: January 15, 2008, 04:45:22 pm »
Yessir.
Dyno tommorow. ;D
Pugsy
76 C10 LWB
TPI 350
« Reply #126 on: January 15, 2008, 05:34:39 pm »
Those looks great.  Definitely post you dyno numbers!
Offline JJSZABO
« Reply #127 on: January 15, 2008, 06:32:07 pm »
WOW - purdy!! :D
Can't wait for the dyno numbers.
Jeff
86 Chevy C-10
350, TH400
Offline 123 pugsy
« Reply #128 on: January 16, 2008, 02:34:21 pm »
Thanks guys.
Good thing I originally thought to go to the dyno. I went there originally with167.73 max HP.
Today with new air breather and headers I have 212.99 rear wheel HP.
Net improvement:45.26 HP
Original run for torque:245.72 ft/lbs torque.
Today with breather and headers : 292.52 ft/lbs torque.
Net improvement: 46.8 ft/lbs torque.
Headers only improvement: 23.09 HP
                                       26.65 ft/lbs torque
Also improved is the air/fuel ratio. You can see it running nicely beside the dashed line at the bottom.
HP and torque are not huge but it smokes the tires , takes off great and is getting good milage.
PERFECT! ;)
Pugsy
76 C10 LWB
TPI 350
« Reply #129 on: January 16, 2008, 02:56:30 pm »
MUCH better!!!
« Reply #130 on: January 16, 2008, 05:23:14 pm »
Nice! So what did they charge you to dyno it?
Offline jonkmbll89
« Reply #131 on: January 16, 2008, 07:41:13 pm »
Your headers look good under the hood.
Offline 123 pugsy
« Reply #132 on: January 16, 2008, 08:05:38 pm »
$100. First time was $140. I think I made a good investment with this. They pegged the problems right on the head. I'll save that in fuel in not much time at all.
Thanks. The fella at the dyno said equal lengths weren't too important but I think its best to do things properly. She runs real good so I think every little bit helps.
I do have a little bit of a rough idle still and in drive at a stop. Dyno dude said probably because of the cam??? Don't know if I'll bite on this one.
Any comments on this one guys?
Pugsy
76 C10 LWB
TPI 350
« Reply #133 on: January 16, 2008, 10:26:56 pm »
WOW!!! Some nice gains. good work. ;)
Dan
Offline Redneckchevy
    • Photo Bucket
« Reply #134 on: January 16, 2008, 10:31:09 pm »
Sweet job! im impressed with the horse power gain !
