Author Topic: Turn Signals  (Read 4401 times)
Offline Bitzer!
  • Smiles per gallon
Turn Signals
« on: December 06, 2007, 01:40:53 pm »
Hi guys- just a quick one. My turn signals & 4way dont work. The question is do they all run through a fused wire and if so does anything else?
Also the washer wont squirt- motor makes no noise but haven't had chance to get a meter to it for power.
Unfortunatley its dark when i go to work, dark when i get home from work and it seems to be raining 24/7
1979 GMC CrewCab  C20 1t
Re: Turn Signals
« Reply #1 on: December 06, 2007, 02:13:30 pm »
They are on a fused circuit.  Do they just come on and don't blink?
Offline Bitzer!
  • Smiles per gallon
Re: Turn Signals
« Reply #2 on: December 06, 2007, 06:05:39 pm »
nothing at all from turn or 4way so i guess it could be relay but i've read a lot about these fuse things I wasn't sure where to start looking!
Re: Turn Signals
« Reply #3 on: December 07, 2007, 12:55:42 pm »
Check the fuses in the fuse panel.  does the interior lights come one, instrument lights?
Offline MOBrooks
Re: Turn Signals
« Reply #4 on: December 07, 2007, 01:57:01 pm »
I have been having the same problems.  Check the fuses under the drivers side dash and then the grounds.  I also had to clean some of the contacts where the wiring harness connects at the firewall right next the the brake master cylinder.  My taillights and headlights now work but no front blinkers or driving lights...Can anyone help me also?
