Author Topic: oil pressure?  (Read 14725 times)
Offline txtj79
  • 1980 Chevy C-10 SWB
oil pressure?
« on: December 09, 2007, 07:47:37 pm »
I have a 1980 Chevy with a 350.  The oil pressure seems really low.  If 12 o'clock is 30, then mine is reading 15-17psi while cruising and only about 10-12 when idling?  Does that seem low to anyone else?
thanks,
T.J.
« Last Edit: December 09, 2007, 09:50:59 pm by txtj79 »
Offline monte85
Re: oil pressure?
« Reply #1 on: December 09, 2007, 09:04:29 pm »
on the guage in my 87, the 12 o'clock position is the 30 mark. my truck has a new motor and stays around the 45 to 60 psi mark all the time. my monte carlo has a well worn 350 and at idle only makes around 30 psi and goes up to 45 or 60 while driving. as the engine wears, oil pressure will drop. one of my motor manuals says that average oil pressure for a 1980 350 motor is 45 psi.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: oil pressure?
« Reply #2 on: December 09, 2007, 09:29:52 pm »
recheck the numbers on your guage.  60 should be max--all the way right.
Your pressure, when driving, should be at or above 45.  When at idle, it will go down 10-15 lbs.
Offline txtj79
Re: oil pressure?
« Reply #3 on: December 09, 2007, 09:50:01 pm »
Sorry, I messed that description up.  I meant to say that 12 o'clock was 30psi.  My truck is barely showing 15-17 psi when cruising and 10-12 psi when idling.  Should I be alarmed?  The truck runs good otherwise but it is burning a lot of oil.
Thanks,
T.J.
Re: oil pressure?
« Reply #4 on: December 09, 2007, 10:08:12 pm »
For idle that isn't low, that is normal.  General rule of thumb for a stock motor is 7-10lbs at idle and a additional pound for every 1000 rpms.  When cruising, what speed are you talking about?  60mph or 30mph.
Offline txtj79
Re: oil pressure?
« Reply #5 on: December 09, 2007, 10:10:48 pm »
I'm talking 65-70 mph when I say cruising.  Even when I floor it getting on the freeway, it still doesn't go above 30-32.  What do you think, Chris?
-T.J.
Offline 1976Scottsdale
Re: oil pressure?
« Reply #6 on: December 09, 2007, 11:09:00 pm »
Means whe is getting loose on you.  I reringed and rolled new bearings in mine and a pump and I get 75 on startup, 27-35 at hot park idle, 24-25 at in gear hot idle, and 50-80 at speed, depending onWhat speed.  and a happy 85-100 floored.
Offline 123 pugsy
Re: oil pressure?
« Reply #7 on: December 10, 2007, 05:00:06 am »
Sounds like its time for a rebuild if its burning a lot of oil. You can just keep driving it till she goes. It could take a while but you will spend alot of money on oil.If it were me , I'd be dumping the cheapest discount oil I could find in there.
Pugsy
76 C10 LWB
TPI 350
Re: oil pressure?
« Reply #8 on: December 10, 2007, 10:46:09 am »
I think it is getting on in age if it is below 30 at 60mph.  Dump some thicker oil in there.  What are you running in it now?
Offline JJSZABO
Re: oil pressure?
« Reply #9 on: December 10, 2007, 01:31:03 pm »
Anyone remember STP engine honey?  Marvels mystery oil.  How fast can you sludge up a motor?
Snake oil for engines.....
« Last Edit: December 10, 2007, 05:40:41 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
Offline txtj79
Re: oil pressure?
« Reply #10 on: December 10, 2007, 02:49:26 pm »
Yeah, I'm running 10w-30 in it.  I'm thinkin of going with some Rotella for diesels.  My dad seems to think it will help.  What do you think?
I came to the conclusion that its burning oil because the right side tail pipe spits out a lot of black soot at start up.  Is that a logical conclusion?
Thanks,
T.J.
Offline JJSZABO
Re: oil pressure?
« Reply #11 on: December 10, 2007, 05:44:10 pm »
Thicker oil is just a bandaid (in my opinion).  It would work in the short turn.  Sounds like a rebuild to me. :'(
Jeff
86 Chevy C-10
350, TH400
Re: oil pressure?
« Reply #12 on: December 10, 2007, 06:17:02 pm »
I would be a bandaid, but it would keep it running long enough to get a replacement.
Offline okuma
Re: oil pressure?
« Reply #13 on: December 10, 2007, 06:28:53 pm »
TRY USUNIG 20-50W OIL  ;)
Re: oil pressure?
« Reply #14 on: December 10, 2007, 08:02:23 pm »
Thanks,
T.J.
No, oil burning would be bluish grey smoke. Black smoke is unburned fuel.
I agree just put 20w50 until you are ready to rebuild...
