Author Topic: need advice on lifting a 2wd...  (Read 20316 times)
Offline shaved80
« on: December 20, 2007, 12:13:51 am »
i'm used to gettin them closer to the ground, so i'm gonna need your guys' help on this one...
my dad is looking to lift his '84 c20 2x (454), and i've decided to buy the parts as a xmas present. for the rear, are 3" blocks sufficient? as for the front, to level it out it'd need 5"...would lift coils and spacers be a good idea, or should i shell out the money for something like spindles and coils? thanks for any help!
ps: if anyone has any pics of their 2x with about 2-4" of lift, post up!
Offline 123 pugsy
Re: need advice on lifting a 2wd...
« Reply #1 on: December 20, 2007, 05:33:33 am »
2" lift blocks in the back and the wrong springs on the front. 30.5" tires.
Pugsy
76 C10 LWB
TPI 350
Offline Fordeatinz71
  • 78k miles and counting
« Reply #2 on: December 20, 2007, 03:18:03 pm »
well, you can get a 2" lift from Rough Country for $509.  sadly, that's one thing the F*rd boys have on us, we can't get much lift out of our older 2wds simply because of our suspension design...ours just rides/handles a lot better...
http://www.rockymountainsusp.com/GM_2WD.htm
« Reply #3 on: December 20, 2007, 05:57:25 pm »
my dad is looking to lift his '84 c20 2x (454), and i've decided to buy the parts as a xmas present. for the rear, are 3" blocks sufficient? as for the front, to level it out it'd need 5"...would lift coils and spacers be a good idea, or should i sheck out the money for something like spindles and coils? thanks for any help!
1985 C-20 454 stock tires and height.  Just to compare with your dads
Offline 81C10
« Reply #4 on: January 12, 2008, 08:24:01 pm »
You're truck looks awesome. It seems to have the stance of a 4x4. What springs did you use for the front? BTW, that truck reminds me of my '73- it is also yellow. Does yours happen to be  'Sunset Gold' ?
'73 GMC C15 307 3 on the tree
'81 GMC C15 5.7 Diesel TH350 (doesn't run yet)
'82 K10 6.2 Diesel TH350 (daily driver)
'84 K20HD 383 TH400
Offline 123 pugsy
« Reply #5 on: January 13, 2008, 06:55:08 am »
Thanks.
The springs for the front were a screw up. I ordered the regular duty springs and they packed something else into the box so I don't know what they are.They have the same thickness as the  HD springs, but I won't say for sure that's what they are.
The color is as close to a Boss Mustang as I could get. I was flipping thru a book at the paint store and seen a picture of the car and had to have it. I've got the code for it somewhere...
Pugsy
76 C10 LWB
TPI 350
Offline prerunner1982
« Reply #6 on: January 30, 2008, 06:47:27 pm »
I realize this thread is a bit dated, but thought I would reply anyways.
With a 454 the average lift spings may not lift as much as advertised.  I used stock HD coils on my 82 c10 and gained about 1.5-2", enough to level the truck out. You can add a coil spacer and some lift coils but the front will max out on down travel due to the front end design.
Unfortunately lift spindles are not available for the 73-87s, they used to be from AIM, but they stopped making them some time back and I have never heard anything good about AIM.
« Reply #7 on: January 30, 2008, 09:48:25 pm »
FabTech makes a-arms that lift it 3 inches. I am modifying some for my wifes 3/4 ton. I know it is the wrong year model but Here is her driver it is 2 wheel drive w/ 8 inch fabtech lift. handles better lifted than it did stock
« Reply #8 on: January 31, 2008, 10:42:45 am »
Fabtech only has spring lifts for these now.
« Reply #9 on: January 31, 2008, 07:49:53 pm »
Darn, I wanted one more set of the a-arms. And I need to correct my previuos post. It is a 6 inch lift not 8 inch. Fat fingers got in the way.  Are the springs still 3 inch lift
« Reply #10 on: February 01, 2008, 09:53:45 am »
think so..
