Author Topic: 83 c10 re-innovated Pro Touring  (Read 516757 times)
Offline the dan
Re: 83 c10 re-innovated, air ride
« Reply #345 on: December 31, 2012, 02:18:18 am »
worked my ass off this new years break, 14 hour work day on saturday working on this pig
it all started.....
Thursday when my axle shafts came back from moser for the resize for the C5 front brake adaptation im making. and i want all the lug patterns the same (4.75 on 5)
then long story short non of the hubs matched up and the flange OD was too large, chucked it up and turned my shiney just resurfaced axle shafts.
Then i had to bore the center hub of the rotors to fit the 9" then lasercut brackets to fit the rotors
I then turned some custom spacers on both sides. one to fit the odball bolt that came OEM on the C5 front calipers, and the other to space the new weld on bracket i lasercut away from the flange of the axle
I did what i had to do to the front wheels to the rear (lug convert the 5.5 on 5 to 4.75 on 5 which involved welding in a new hub piece. got the wheels on and finished the X on the back of the cage, as well as other small loose ends
i can see some light at the end of the tunnel. could be a train, could be a homeless man... either way
Dimple die, and tied to the cab, only tack'ed for now untill we finish the seatbelt bars and door bars
Offline the dan
« Reply #346 on: January 22, 2013, 02:42:43 pm »
Momo steering wheel and SweetMFG quick release, courtesy of my girlfriend
i had to make a threaded inner shim to convert it from a GM style ididit column to a 3/4 shaft style Sweet splined disconnect, pictures to come once done
and last but not least a little feeling of things finally falling into place.
Offline the dan
« Reply #347 on: January 22, 2013, 11:03:39 pm »
there is the spline for the sweetmfg quick release, i made an allen headed nut to slip into the 3/4 shaft and welded it in with a 9/16 fine thread to adapt to the column.
ill have the column wheel cover done tomorrow, laser cutting it machining it out of stainless and reaming a .997" id to press fit that splined shaft at the bottom
« Reply #348 on: January 24, 2013, 02:27:48 am »
Nice!
Offline the dan
« Reply #349 on: January 27, 2013, 10:37:18 pm »
Offline the dan
« Reply #350 on: January 31, 2013, 02:41:03 pm »
Offline the dan
« Reply #351 on: February 26, 2013, 12:27:33 am »
shock crossmember is done, finally just need to make another pass of welding
air ride controls done
i am really disappointed in what is out there for steering column brackets. I almost cut up a top fuel dragster connecting rod, but the main bearing was larger than 2 inches, and Ididit's bracket is OK but its $90, not worth it to me. heres what i made in 4 hours with some quick thinking
« Reply #352 on: February 26, 2013, 06:49:53 pm »
Looks sick
Offline Mcnally351
« Reply #353 on: March 01, 2013, 10:06:18 pm »
Incredible.
Offline pcguysam
  • Total N00B
« Reply #354 on: March 04, 2013, 02:09:20 pm »
I know it's not polite to stare, but all I can do is just sit here with my mouth open.  I actually had to wipe drool off of my desk a minute ago.  I'm totally impressed that's saying something for me.  Outstanding job!
81 C10 Custom Deluxe Stepside Purchased 2/2013
Offline the dan
« Reply #355 on: March 04, 2013, 11:35:12 pm »
thats very polite, who are you kidding, gives me the gitters!
Incredible.
its coming along
Looks sick
doors open if you ever around central ct
« Reply #356 on: March 06, 2013, 06:49:03 pm »
I've gotta stop in some time for sure
Offline frotosride
    • WFO CONCEPTS
« Reply #357 on: March 06, 2013, 08:06:24 pm »
Looks good man and there's nothing like the feeling of driving some of the best trucks ever made when you know it was your hands making it go down the road and look so good.
Offline the dan
« Reply #358 on: May 01, 2013, 12:32:49 am »
« Reply #359 on: May 01, 2013, 05:26:29 am »
That thing is sick!
