Author Topic: 1994 4.3  (Read 4934 times)
Offline 75 C20
1994 4.3
« on: January 26, 2008, 09:57:17 pm »
my brothers 94 WT with a 4.3 quit on him while he was driving down the road. my originally thought was lack of fuel . its getting gas but it has no spark.
i wont start up-no spark- i was thinking ignition coil.  i haven't got to take the cap off yet but i thought id get your guys thoughts on this.
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 1994 4.3
« Reply #1 on: January 26, 2008, 10:18:29 pm »
quick way to test spark to dist. is to pull coil wire and crank over engine. I highly recommed doing this with a spark tester like ones used to check fire to spark plugs. If you don't have one, inserting a screwdriver in one end and the placing next to the block will work. DONT HOLD ON TO THE SCREW DRIVER< AND MAKE SURE THERE ISNT ANY FUEL ON THE INTAKE. It will hurt. Use clean rags or such to hold the screw driver shank off of the block about 1/16 to 1/8 inch. This should allow you to see the spark. I am not familiar with the engines, but if they are equipped with a crank sensor, this can be an issue as well, but I don't thin k they have one
Offline Fordeatinz71
  • 78k miles and counting
Re: 1994 4.3
« Reply #2 on: January 27, 2008, 11:04:13 am »
ignition module...right under the distributor cap...with two plugs coming out of it...
Re: 1994 4.3
« Reply #3 on: January 27, 2008, 01:19:48 pm »
Totally agree. That would be the next step and is not uncommon. Very good point, I forgot about it
Offline 75 C20
Re: 1994 4.3
« Reply #4 on: January 27, 2008, 05:28:24 pm »
got it figured out- was  a lose connection on a wire
Re: 1994 4.3
« Reply #5 on: January 27, 2008, 05:31:20 pm »
1st step in trouble shooting is trouble shooting not parts changing. Glad you fixed it.
