Engine/Drivetrain
Fuel Gauge Issue
Topic: Fuel Gauge Issue (Read 3619 times)
HerkPilot
Fuel Gauge Issue
February 08, 2008, 04:03:53 pm »
I've got an '85 with dual tanks and the left tank reads correctly when selected but the right one shows well past full no matter how much gas is in it. I've read on here it may be a grounding issue but anyone want to confirm that?
Thanks
1985 K10 LWB
350 w/ Vortec heads
700R4
Stock Suspension w/ 31's
zieg85
Re: Fuel Gauge Issue
February 08, 2008, 07:41:17 pm »
My 85 does the exact same thing and it is the ground as I have verified it.
choptop
Extended cab fanatic
February 08, 2008, 10:55:01 pm »
replace the tank selector switch first (its cheap) then check grounds. My 81 does this every 3-4 years and all I do is replace the switch
February 11, 2008, 11:06:20 am »
You don't have to replace the switch that often, you can clean it up first...
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6537.0
Engine/Drivetrain
Fuel Gauge Issue
