Author Topic: This engine is stupid, or maybe I am......???  (Read 8822 times)
Offline 85MudMonster
« on: February 10, 2008, 07:58:23 pm »
okay started taking apart my olds 350, the distributor is stuck, usually you pull up and wiggle it back and forth to get it out right? well, I got nothing no movement in the dist. at all, if you wiggle the camshaft the rotor part of the dist will move back and forth as well? What am I doing wrong, or maybe the dist. just needs some convincing that it is time to come out.....
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline jonkmbll89
Re: This engine is stupid, or maybe I am......???
« Reply #1 on: February 10, 2008, 08:17:29 pm »
How old is the motor? Maybe it has oil caked up around the housing. Sounds like it needs a little persuasion.
« Reply #2 on: February 10, 2008, 08:26:33 pm »
Yeah, I already beat it to death with a mallet, even bent the vaccuum advance. It still won't come out? Is there something I can put on it, or need to take off of it....I've never had this much trouble with one of these before.....I just want it to come out. Don't care how just want it out!!!
Dan
« Reply #3 on: February 10, 2008, 08:30:38 pm »
You took out the hold down clamp right?  ;D Soak it with some penetrating oil. Rotate the housing back and fourth. It may take some working but you'll get it out.
« Reply #4 on: February 11, 2008, 10:21:04 am »
If you don't care about the distributor use a clamshell porta power. It will come out.
Offline DnStClr
« Reply #5 on: February 11, 2008, 11:30:06 am »
You might be able to loosen it by using a 14" pipe wrench in the outside of the housing and rust blaster or carburetor cleaner on the shaft. .turn the wrench back and forth to try an loosen the shaft. You might have to take the oil pan off to check the oil pump too, after beating with the hammer.
Don
87 Chevy Silverado
« Reply #6 on: February 11, 2008, 01:32:02 pm »
the hold down clamp??
Just kidding, it's off, anyway, I've used some PB blaster onit, and a 14" cresent wrench on it and it still wont budge...I've taken out two of these before and never had it be this hard...I just want the block, the rest will be new including oil pump, so I'm not to worried about that, But until I get this off I can't get the engine acid dipped, or the magnafluxing thing to check for cracks...
Dan
« Reply #7 on: February 11, 2008, 01:42:14 pm »
I had a Ford 400M back when I was a kid that did that to me once. I eneded up snapping the housing off. It went to the bone yard with it still in it.
« Reply #8 on: February 11, 2008, 05:18:41 pm »
Well turn the engine upside down and soak it with pb from the inside. Then take a brass punch and give it a few love taps while you give it the chubby checker
« Reply #9 on: February 11, 2008, 05:53:58 pm »
okay I'll have to give that a try, so soak it with pb blaster and then use a brass punch to tap on it as I try to wiggle it out...seems like it might work.
Dan
Offline jonkmbll89
« Reply #10 on: February 11, 2008, 07:02:19 pm »
I wounder if the roll pin has worked its way out just enough to catch on the motor and not allowing the dis. to come out. ???
« Reply #11 on: February 12, 2008, 05:48:38 pm »
Awww man I hope not, how would I be able to tell if it did??
Dan
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #12 on: February 13, 2008, 12:04:09 am »
This may be a little crazy, but, could you take the oil pump off, keep the pin going up into the distributor in place, and take a mallet and tap the pump pin upwards?
How about putting a torch five or six inches away from where the distr. meets the intake to heat it up around the base? Then work it back and forth.
« Reply #13 on: February 15, 2008, 04:02:44 pm »
it's an olds block, dist. doesn't go through the intake, it goes through the back of the block. I'm gonna try some of these ideas this weekend and see if I can get it out.
Dan
