Author Topic: '77 K30 Crew Cab Longterm Restomod  (Read 47421 times)
Offline Mr. Lee K30
  • It’s been awhile...
« on: February 15, 2008, 02:17:07 am »
« Last Edit: August 06, 2009, 10:29:14 pm by Mr. Lee K30 »
1978 C10 Longbed 2WD
250 I6 & 3spd Saginaw
Soon to swap in TBI 305 and 700R4 from ‘88 C1500 2WD
Offline 79diesel
Re: '77 K30 Crew Cab Longterm Restomod
« Reply #1 on: February 15, 2008, 06:08:58 am »
looks like a good starting point...what are the plans?
Offline plowking_90
« Reply #2 on: February 15, 2008, 04:10:49 pm »
nice lookin truck leave it stock :)
« Reply #3 on: February 15, 2008, 04:46:53 pm »
No way! pimp that ride!
Offline xtremjeepn
« Reply #4 on: February 15, 2008, 08:25:04 pm »
Nice. I have been waiting for more people to resto-mod these old crew cabs, especially with the cost of a new one.
Here is mine.....in progress.(have to go a few pages back to get to the crew cab)
http://forum.73-87chevytrucks.com/smforum/index.php?topic=4725.0
Cole
Restomod Crew Cab Short box on 37"s
Offline Mr. Lee K30
« Reply #5 on: February 16, 2008, 03:17:38 am »
So far the plan is to back on the road (been sitting for a few years) and make sure everything is working good and all.  When I changed the oil some radiator fluid also drained out with the oil :(  So we'll see what happens when I fire it up this weekend, might have to already look for another motor or something.
Then...
-Put on some wheels and tires to replace the stock ones
-Redo the interior including installing High Back Bucket seats I got from a '78 Blazer (once I find the right brackets)
-Bodywork & rust removal/prevention
-Paint job  ;D
Offline JRConnieK10
« Reply #6 on: February 16, 2008, 09:22:43 am »
I like it. I think when I get done with the truck I'm workong on I want to build a crew cab next.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline SUX2BU99
« Reply #7 on: February 19, 2008, 11:32:51 am »
There is a local truck around here that is a dumped crew cab with a windowless shell on the back. The cool part is he limo'd it by adding on the back 1/2 of another crew cab, so it's a 6 window.
Offline bake315
« Reply #8 on: February 28, 2008, 03:38:04 pm »
Then...
-Paint job  ;D
Sounds like you're headed in the same direction I'm in.  I'm in the process of looking for a good 3+3 resto candidate, and plan to take a sort of "slow boat" approach.  I actually got a lead on a K30 crew last night that sounds promising, and only about 50 miles away. Who knows, we might end up comparing a few notes before it's all said and done.
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline Mr. Lee K30
« Reply #9 on: March 04, 2008, 03:11:17 pm »
Hey that sounds good  :)
Well I got some nicer wheels and tires on it.  Tires are 265/75/R17 (32") BFG Rugged Terrain T/A's (Les Schwab takeoffs) & 17x8 Rims.  $500 out the door, tires are good enough to get by until I can afford some new rubber.
« Last Edit: August 06, 2009, 10:39:51 pm by Mr. Lee K30 »
« Reply #10 on: March 04, 2008, 03:36:41 pm »
New pics should go here not the projects page.
Offline Mr. Lee K30
« Reply #11 on: March 04, 2008, 08:08:40 pm »
No prob Capt  ;)
My "Stock" 400 Motor
I just sold my bucket seats to a coworker for his '73 K20 so I'm definately gonna keep the bench seats, maybe replace the front one with something a little nicer.  Hopefully this weekend I'll get the inside and out cleaned up, the new fuel pump and hoses installed and fire it up again...
(Edit: Haha bought the seats back as I found a matching rear bench seat and took the time to find the correct brackets from a late '70s early '80s Suburban)
« Last Edit: August 06, 2009, 10:45:55 pm by Mr. Lee K30 »
« Reply #12 on: March 05, 2008, 01:50:24 pm »
Sweet!, BTW, this is YOUR thread, so you can put the whole build up here.  If you start a specific project on it, you can detail it in the project forum.  IE, Carpet Install, Seat Cover how to etc...
Offline Mr. Lee K30
« Reply #13 on: March 23, 2008, 10:48:58 pm »
Well I was able to fire up the truck again after having to replace the bad fuel lines and some other items.  Suprisingly no white smoke whatsoever, even after it fully warmed up.  The carb is gonna need a rebuild as it had to be tweaked to keep it running at idle among other things.  Took a test drive on the back roads with my buddy and it did alright with the exception of the cruise control sticking  :o (thankfully only going 30 mph).  So now I'm gonna concentrate on all the little mechanical things (and disabling the cruise control for now  ;)), then onward to other fun stuff  :D
Offline BC3+3
« Reply #14 on: March 27, 2008, 02:38:19 am »
Lots of potential there.  I've been planning a build of one of these for awhile and will finally be ready to buy one this summer.  Sure they burn fuel, but parts are cheap and plentiful and easy to work on.  What axles and gear combo does your truck have?
