73-87 Chevy & GMC Trucks
Rear slider Weatherstripping
Topic: Rear slider Weatherstripping (Read 7503 times)
JJSZABO
March 13, 2008, 11:07:54 am »
I have the GM rear slider that I need to install. I was told that the rubber seal for the original sliding window is no longer available. Has anyone replaced their single piece glass with a slider and what gasket did you use? Thanks
Jeff
Jeff
86 Chevy C-10
350, TH400
Dragon
Re: Rear slider Weatherstripping
March 13, 2008, 12:05:35 pm »
No Longer Available through GM Yes, but should be available through any well stocked Auto Glass Shop(Speedy Auto Glass/Safelite/ETC)....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
JJSZABO
March 13, 2008, 12:10:53 pm »
No...already checked local dealers, they say no also.
Well, to be honest I only called safetyglass and banner glass - I'll keep checking.
Jeff
86 Chevy C-10
350, TH400
March 13, 2008, 01:59:21 pm »
are you talking about the gasket for the complete glass? It is the same if it is a GM slider.
JJSZABO
March 13, 2008, 02:21:45 pm »
Yes Chris, so ANY aftermarket rubber seal will work?
Jeff
86 Chevy C-10
350, TH400
March 13, 2008, 02:57:53 pm »
Yes. IF it is a GM supplied slider. I removed my Slider that came on my 87 and replaced it with the same gasket. If the current one has a small area that a glass will go into you are set to get just a regular glass gasket. Got a pic?
JJSZABO
March 13, 2008, 07:49:23 pm »
This is the inside - it says PRESTIGE on the lock:
This is the outside:
This is the flange:
Thanks for your help Chris
Jeff
86 Chevy C-10
350, TH400
March 14, 2008, 10:19:38 am »
It's thin like the glass that came out, just get a regular gasket.
JJSZABO
March 14, 2008, 04:00:08 pm »
OK thanks
Jeff
86 Chevy C-10
350, TH400
