Author Topic: 4-speed gearshift lever removal and reinstallation for new carpet  (Read 12652 times)
Offline got2haul
I'm installing new carpet this weekend.  I want to remove the 4-speed shifter so it'll be easier to mark and cut the hole for the shifter.  I looked in the service manual and it says to use a certain tool (J-8109, if my memory serves me correctly) to "press down and turn counterclockwise to release the shift lever for removal.  Pretty vague.  It normally shows at the end of the chapter what the tool looks like, but they neglected to include that particular tool.  Could anyone who has done this before enlighten me?  Can the shifter be removed and reinstalled with a common tool?
« Last Edit: April 03, 2008, 09:10:05 am by got2haul »
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline Toolmaster
Re: 4-speed gearshift lever removal and reinstallation for new carpet
« Reply #1 on: April 03, 2008, 09:19:59 am »
Have you removed the boot ?
You might be able to use some large snapring pliers, Look at the retainer and see what type of slot's are cut for the tool. Might just have to push the retainer down and rotate. Be sure to have the trans in neutrel before removing the shifter.
Offline got2haul
« Reply #2 on: April 03, 2008, 09:54:22 am »
No, I haven't yet removed the boot.  This is a job I intend to do Saturday.  I did a Google search and found some information -- a couple threads on other forums ask the same question.  One reply was that you can use two screwdrivers (on in front and one in rear) to press down, and with a third hand, turn the retainer counterclockwise 1/8 turn.  Problem is I only have two hands!  Maybe it can be turned with the screwdrivers while pressing down?
What about reinstalling it?  Does it simply pop back in, or do you have to go through the same thing to install it?
Offline Toolmaster
« Reply #3 on: April 03, 2008, 10:14:10 am »
Yep ! Reverse order to install.
It's not that hard to do, Be sure to clean the area or any dirt buildup as to prevent dirt entering the trans. Stuff a rag in the hole after you remove the shifter to keep it sealed up and wrap one around the shifter to keep the grease from soiling your new carpet.
« Reply #4 on: April 03, 2008, 10:14:17 am »
Push down and rotate the cup while in Neutral with your special tool. That special tool would be your fingers. That's it... then just pull the shifter straight up. You'll see the 2 roll pins will be lined up in the grooves to remove it. I assume you have a granny tranny
Offline Toolmaster
« Reply #5 on: April 03, 2008, 10:19:50 am »
If it looks dry around the retainer then spray some PB Blaster around it first.  It's that easy !
« Reply #6 on: April 03, 2008, 10:59:29 am »
I agree, all you need is your hand to push it down and spin it to get the shifter out.
Offline got2haul
« Reply #7 on: April 03, 2008, 12:48:00 pm »
This can be done without tools?  Cool.  I just happen to have some PB Blaster, too.  Thanks for the responses!
Offline ccz145a
« Reply #8 on: April 03, 2008, 04:04:17 pm »
Quote
PB Blaster
Uh, That would be "Weasle Pee", wouldn't it Blazin?  :D
Offline 75 C20
« Reply #9 on: April 03, 2008, 08:36:13 pm »
i gotta say- the one on my 75s tranny poped right out no problem. but my 79 was really stiff and it was veyr hard to get out- like the spring was real stiff on it
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline got2haul
« Reply #10 on: April 04, 2008, 07:29:18 am »
The shifter came out pretty easily.  Thanks!
« Reply #11 on: April 04, 2008, 07:46:49 am »
Yes it would be! ;D
I have had a few over the years that turned hard. I just use my monster channel locks then.
