Author Topic: Flat Tires and Portable compressors  (Read 14374 times)
Offline Bitzer!
  • Smiles per gallon
Re: Flat Tires and Portable compressors
« Reply #15 on: May 20, 2008, 02:03:11 pm »
If you use that "stitching" stuff over here on road tyres its illegal, You can use it on aggricultural stuff tho
One more reason you should be here not there ;)
We have the stuff Vile carries - TyreWeld but it renders the tyre unrepairable as the glue soaks into the rubber and makes it go spongey and a mushroom patch wont stick. The mushroom patch is a normal radial patch with a stalk that gets pulled thru the hole from the inside and seals the hole in the trad to stopping the steel cords from rusting and causing separation!
Yup Chris - the way things are here I'd much rather be there!
Note- hope to be visiting Ohio next year meeting up with friends we met on our cruise holiday  ;D
1979 GMC CrewCab  C20 1t
Offline ccz145a
« Reply #16 on: May 20, 2008, 02:26:09 pm »
Quote
The way things are here, if you decide to stay... Who knows, maybe no one will be the wiser.
