Author Topic: What causes a motor to spit through the carb?  (Read 29232 times)
Offline team39763
« on: May 24, 2008, 07:06:07 pm »
A friend told me it could be stuck valves, but I don't know.  I tried the 670 Avenger carb on my truck and it ran like crap, just like my Holley 750DP.  It idled rougher than ever and was rich enough to burn my eyes.  I tried setting the idle mixture, but it made no difference.  Floats were perfect, fuel pressure was normal.  But I did notice it spit.  I don't know what to do with my truck.  I'm thinking of junking the 6.0 and putting in a stock 5.3 with fuel injection.  But I don't understand what went wrong with this motor.
Re: What causes a motor to spit through the carb?
« Reply #1 on: May 24, 2008, 10:02:16 pm »
Try another carb or put the fuel injection back on the 6.0, but not replace it with the 5.3. It's too cool as is. Don't know the cure for sure, but the carb sounds like the issue.
Offline TexasRed
« Reply #2 on: May 24, 2008, 11:18:12 pm »
If by spit through the carb, you mean backfire, it could be valves being too tight, too lean of a mixture (ie, there's a vacuum leak). I'd check to make sure all your vacuum lines are hooked up, including the one in the back for the power brakes.
Offline HAULIN IT
« Reply #3 on: May 25, 2008, 07:58:32 am »
Team, Please explain the "spit" in more detail. Does it do this anytime or only when you try to blast from idle? If you want to sort out the inner motor from carb working, a compression or leak-down test will tell you if the intake valve is open. Could just be a lean "pop" if it is as you try to accelerate, meaning you need more fuel (pump cam,squirter) most Holley carbs are rich at idle, but that does not mean it is rich once off idle. Lorne
« Reply #4 on: May 25, 2008, 10:50:44 am »
Check your firing order first or are you using a coil direct with stand alone cpu? Not really sure what your set up is. If it's backfiring through the carb it's usually an ignition timing issue. If it's popping through the carb check your valve timing and adjustments.
Offline team39763
« Reply #5 on: May 25, 2008, 02:51:10 pm »
Yeah, it's more of a popping, not really any fire.  I can actually see fuel being spit upwards out of the carb.  I didn't get to drive it, because it would barely idle.  I was too scared to drive it, it sounded like it wanted to puke it's guts out though the intake.
Vile, I'm running the individual coils controlled by stand alone Cpu.  I believe my initial timing is set to 12*....that's a good place to start right or should I bring the timing down more?
I'm gonna send my 750 off to a carb builder, but I decided to go through it myself one more time and clean everything really good this time.  I can accept the fact that something doesn't work, but I'd like to understand what exactly is going wrong(or what I did wrong).  I'm gonna try the 750 once before I send it away.  I'll let ya'll know if it's doing the same thing.
Offline Blue 82
« Reply #6 on: May 25, 2008, 05:57:38 pm »
That's called reversion
How much cam are you running?
How much vacuum do you have at idle?
If your vacuum is too low, the power circuit(s) are gonna kick in, thus giving you a pig rich idle.
There are anti-reversion plates (or spacers) available
While they are not the cure for all that ails you, they do help.
Offline team39763
« Reply #7 on: May 25, 2008, 07:52:23 pm »
I put the 750 back on there, but it ran like crap -  just like before.  One thing I did notice was it threw sparks while I was tightening down one of the bolts.  I don't know jack about electrical systems, so I may have a hot wire somewhere that's supposed to have a ground or something like that.  Would that explain why my battery is always dead if I leave it connected overnight?  I'm gonna leave it alone for a while since there's gasoline all over the motor from setting the floats and I don't want to light it up.
« Reply #8 on: May 25, 2008, 08:04:25 pm »
You see sparks from where? Yeah disconnect your negative battery cable.
Offline team39763
« Reply #9 on: May 25, 2008, 10:22:08 pm »
The sparks came from the carb bowl screws.  I think it was something with the wires going to the alternator.  I did a crappy job of wiring this motor, so I'm gonna take some time and go through all the connections and see what's out of place.  After moving the alternator wire away and taping it up, the motor ran pretty good.
« Reply #10 on: May 26, 2008, 08:13:11 am »
Yikes! You better go through that puppy real good. If your B+ is grounding to the block or intake and you have no circuit protection you can kiss that computer good bye.
Offline team39763
« Reply #11 on: May 26, 2008, 10:49:00 am »
I'm thinking that I messed up with the alternator wiring and the starter wiring.  I'm gonna go look at some other trucks and see how they're wired(as in what goes where).
Offline team39763
« Reply #12 on: May 27, 2008, 04:10:33 pm »
OK I think I messed up.  I have 2 hot wires going to the alternator and no ground, which would cause the alternator to try to ground through the motor?  I don't know.  Could that be my problem?
« Reply #13 on: May 27, 2008, 04:16:41 pm »
No. the alternator is case grounded.
Offline team39763
« Reply #14 on: May 27, 2008, 04:22:31 pm »
Well what wires need to be hooked up to the alternator?  It's one of those with only one wire coming out of the connection and the thick wire on the stud on the back.
« Last Edit: May 27, 2008, 04:26:25 pm by team39763 »
