Author Topic: Tilt column ball bearing question  (Read 13392 times)
Offline 80stepsideguy
« on: June 01, 2008, 08:34:42 pm »
Got a question,
i konw this has been addressed before, i read many of the topics on the seach but.I got this tilt column from a 1982 GMC high sierra and the tilt part is tight but the swivel ball was loose, i took it all apart and realized the bearing that it rides on the casing was all busted up and the brarings were everywhere.I looked in 1 of the vendor catalogs and dont see thi bearing,Can anyone help me out on where to find it?
Thanks
pat
p.s. also the pivot pin itself is very loose i cna pull it in and out with my hand easily, do i need to take the column down more to tighten this ?
« Last Edit: June 01, 2008, 09:12:02 pm by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline comp
  • 76-77-78
Re: Tilt column ball bearing question
« Reply #1 on: June 18, 2008, 11:54:40 pm »
 find out anything ??
« Reply #2 on: June 19, 2008, 12:44:45 pm »
I have looked around and I can't find anyone listing that bearing.  I am sure the guys the build them can tell you where to get them from.
Offline comp
  • 76-77-78
« Reply #3 on: June 19, 2008, 12:50:44 pm »
 i have two that i need to go thru
« Reply #4 on: June 19, 2008, 12:55:41 pm »
might can ask this place.  They do good work.  Don't know if they will tell you where they get them from though...
http://www.gmtiltsteeringcolumn.com/
Offline comp
  • 76-77-78
« Reply #5 on: June 19, 2008, 01:04:17 pm »
 thanks i'll try
« Reply #6 on: June 19, 2008, 02:46:48 pm »
Let us know what you find and where.
Offline Dragon
« Reply #7 on: June 23, 2008, 11:09:25 pm »
GM used alot of the same bearings well into early/mid 2000(if not still currently), and are still widely available through your local Dealership....
Here are some of the things you can do to tighten the Column
http://www.superchevy.com/tech/sucp_0707_tilt_steering_column/index.html
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline comp
  • 76-77-78
« Reply #8 on: June 23, 2008, 11:27:20 pm »
  thanks for the link
« Reply #9 on: June 24, 2008, 04:58:10 pm »
This is in the tech section also for the tilt:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=1947.0
I have pics of mine that I did that I need to make into an article also.
« Reply #10 on: June 24, 2008, 05:29:00 pm »
GM still sells almost every part you would need for these columns still.
