Author Topic: Amazingly Simple Home Remedies  (Read 4159 times)
« on: June 05, 2008, 08:18:17 am »
1. If you're choking on an ice cube simply pour a cup of boiling water down your throat. Presto! The blockage will instantly remove itself.
2. Avoid cutting yourself when slicing vegetables by getting someone else to hold while you chop.
3. Avoid arguments with the Mrs. about lifting the toilet seat by using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep a fter you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you'll be afraid to cough.
7. You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
8. If you can't fix it with a hammer, you've got an electrical problem.....
9. Remember: Everyone seems normal until you get to know them.
Offline Fordeatinz71
  • 78k miles and counting
Re: Amazingly Simple Home Remedies
« Reply #1 on: June 05, 2008, 12:47:23 pm »
hahaha, i've seen these a few times but they just never get old!
Offline Unofficial
« Reply #2 on: June 05, 2008, 01:18:49 pm »
I'll keep that one in mind. Sounds pretty useful to me! ;D
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
