Author Topic: Ignition cylinder  (Read 19209 times)
Offline maximus5541
Ignition cylinder
« on: July 27, 2008, 12:25:17 pm »
 Has anyone ever experienced problems with the key cylinder. When i put the key in the ignition and trun it to the run position usually the seat belt and choke light come intermittley, but now i have to jiggle the key to get it to come on, as a result in this the truck will not start, it just cranks over with no spark.
1983 Chevy C10 SWB, 2wd, 350/350
1987 Chevy R20 LWB, 2wd, 305/400
1983 Chevy C10 LWB, 2wd, 305/700r4
Offline cracker0169
    • Myspace
Re: Ignition cylinder
« Reply #1 on: July 27, 2008, 12:49:16 pm »
sounds like bad contacts on the ignition switch under the dash  :-\
Take a voltmeter and check to see if you are getting 12v at the distributor with the key on the 'run' position.
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
Offline maximus5541
« Reply #2 on: July 28, 2008, 01:49:03 pm »
i will try that this evening,  i will post back the results., thanks for the help in advance
Offline maximus5541
« Reply #3 on: July 29, 2008, 09:13:20 pm »
well, i checked it, and there is voltage at the dist. only when i jiggle the key, so the problem lies between the key cylinder and the dist. i know the key turns, and that pulls and pushes a little metal rod up and down the column, then im lost?
Offline cracker0169
    • Myspace
« Reply #4 on: July 29, 2008, 10:35:56 pm »
that rod goes into an igntion switch. possibly the rod is bent or the switch is just wore out. i dont believe they are that expensive but I would the switch and check it out and see if there is any slop in the operation of it all.
Offline 78BBSTEPSIDE
« Reply #5 on: July 29, 2008, 10:42:15 pm »
I 've had several switches go bad through the years. A $20.00 switch that is priceless. No contact=no go! Good Luck
Offline DnStClr
« Reply #6 on: July 29, 2008, 11:22:11 pm »
I'd like to learn more about the ignition switch and rod. Hard to replace? My new 87 Silverado (well, newly bought) has a similar problem where it won't shut off after the key is turned.
Don
87 Chevy Silverado
« Reply #7 on: July 30, 2008, 10:25:15 am »
Check the rack mechanism in the column and see if it's broken.
Offline DnStClr
« Reply #8 on: July 30, 2008, 07:32:03 pm »
Hope I'm not stealing the thread-  The rod for my switch moves up and down too, just like Maximuss's. Actually it looks like it moves just a tad too far down when ignition is turned off. A slight push upward on the rod turns my ignition off. I wonder if I can bend the rod a little to make it align better?
Don
87 Chevy Silverado
« Reply #9 on: July 30, 2008, 09:49:32 pm »
Don, the rack mechanisms are nototrious for breaking in the column which causes these problems. I would pop it apart and check it.
« Reply #10 on: July 30, 2008, 10:05:46 pm »
Here's an article on how to disassemble the steering column
Click Here
Offline maximus5541
« Reply #11 on: July 31, 2008, 01:57:52 pm »
well checked it all out and replaced the ignitoin switch and no more problems.
Offline DnStClr
« Reply #12 on: August 09, 2008, 04:28:02 pm »
Got mine fixed too. The rack mechanism was ok. I had to loosen the ignition switch and move it forward a little bit. ( a bear to get to!) Works good now. no more accessories running when I turn the key off..
Don
87 Chevy Silverado
Offline cwilson jr
« Reply #13 on: January 17, 2009, 07:03:24 pm »
not trying to bring up old posts guys, but there is a link posted above about tearing apart the steering column which may be very useful to me.  it just goes to a random post listing now.  does anyone have the original information, or any detailed information and pics of the ignition rack and lock cylinder?  i can't find any detailed info, including the haynes and old posts.
« Reply #14 on: January 17, 2009, 07:14:41 pm »
What exactly is the problem with your column? Loose tilt?
