Author Topic: 1987 1 ton  (Read 18490 times)
Offline 06gsxrman1000
1987 1 ton
« on: August 03, 2008, 02:02:45 pm »
i purchased a 1987 gmc 1 ton 4 wheel drive dually for $1000.00 about a month ago. The truck has only 82,000 miles on it but was in need of alot of repair. The former owner had only used it in the winter to plow and sand. I removed the cab and body and blasted the frame. i then found 2 spots on the frame that needed to be repaired. I cut out the two pieces and welded in the new pieces. I'm now in the middle of removing the rearend and blasting it. i blasted it today and por 15 the rearend and the frame
Three may keep a secret, if two of them are dead.
-ben franklin
Offline team39763
Re: 1987 1 ton
« Reply #1 on: August 04, 2008, 03:05:11 pm »
What are your plans for it?
Re: 1987 1 ton
« Reply #2 on: August 04, 2008, 08:54:24 pm »
the plans for this truck is to redo everything i want a dependable trruck that i can get fire wood for myself with. I almost purchased a newer mason dump but relized that i dont belong in a new rounded truck. so with that said i am gonna put a stake pocket flatbed dump on it and a plow and use it for a couple driveways and for my wood. When this project is done i am gonna find a c10 and do a frame off resto mod to it
-ben franklin
Offline Thowell
Re: 1987 1 ton
« Reply #3 on: August 05, 2008, 01:04:33 pm »
and the white one ton is what you want it to look like or is that it before you tore it down?
Re: 1987 1 ton
« Reply #4 on: August 05, 2008, 05:06:31 pm »
that is what it was before i tore it down.
-ben franklin
Re: 1987 1 ton
« Reply #5 on: August 13, 2008, 08:59:25 pm »
these are some pictures of my project truck. i think i am getting there lol a lot more work togo but it will all be worth it
http://s156.photobucket.com/albums/t9/06gsxrman1000/my%2087%201ton%20project/
« Last Edit: August 13, 2008, 09:03:17 pm by 06gsxrman1000 »
-ben franklin
Offline hotrod24
Re: 1987 1 ton
« Reply #6 on: August 18, 2008, 07:00:53 pm »
looking good man i need to get my cab off to
1978 pontiac grand prix...
Re: 1987 1 ton
« Reply #7 on: August 19, 2008, 08:26:04 am »
Lookin good
Re: 1987 1 ton
« Reply #8 on: August 19, 2008, 09:41:16 am »
i ordered the one piece driveshaft today will have it in a day or two. just fish paint on the rearend and springs.i cant wait to set it down and not have any spring squeek with the new bushings.
-ben franklin
Re: 1987 1 ton
« Reply #9 on: August 19, 2008, 10:04:51 am »
Did you get the shaft from Camerota's
Re: 1987 1 ton
« Reply #10 on: August 19, 2008, 11:44:23 am »
yes sir i did well actually my old lady brought my old one up so i guess she got it from cameratos lol
-ben franklin
