Author Topic: Dual snorkel air cleaner  (Read 66767 times)
Offline HAULIN IT
Re: Dual snorkel air cleaner
« Reply #15 on: November 08, 2008, 07:28:53 am »
Good Job! Another part of the truck with your own personality added to it
Offline eventhorizon66
« Reply #16 on: November 08, 2008, 10:10:10 am »
Thanks, I hope it also added a handful of horsepower.
'85 C10 SWB 350 700R4 TKO600
Offline cadpwrd
« Reply #17 on: February 28, 2009, 02:19:27 pm »
I hope it's cool with you, I totally want to do that for my truck! Looks cool. I hope I have the hood clearance.
Whatcha gonna do with my 8.2?
« Reply #18 on: February 28, 2009, 02:47:19 pm »
Hood clearance isn't an issue. You can also buy them already made from Spectre. I believe Autozone has the kits in stock. My autozone does anyway.
« Reply #19 on: February 28, 2009, 03:57:53 pm »
Thanks cadpwrd.
Like Vile said, hood clearance isn't an issue.  Doing exactly what I did will cost you the price of two 87-92 air cleaners, a spacer from the same era truck (mine came from an early 90's 4.3 S10), and the corrugated pipe (though I would search for alternatives here - something more flexible).  Oh and the only reason I needed the spacer was to clear my MSD HEI.  You may be able to do without it, as the factory HEI cap is shorter than the MSD's.
Here are your options if you want to buy it ready-made: Schmidt ram air box (seems like the best bang/buck on the market but may not clear the HEI), AIS ram air box (give them a call to find out which one they recommend for you), and Spectre's dual snorkel box.  If I had known about the Schmidt unit before taking on this project, I probably would have gone with that, but the AIS and Spectre units were just too expensive for my taste.
« Last Edit: February 28, 2009, 04:11:03 pm by eventhorizon66 »
Offline cadpwrd
« Reply #20 on: February 28, 2009, 06:38:28 pm »
 The only reason I'm concerned about clearance is my engine. I'm building a Cadillac 500 (8.2) for my truck.  I'll look at the alternatives too. I've got a ton of things to do on the truck before I can worry about the air cleaner.
« Reply #21 on: February 28, 2009, 08:05:43 pm »
Unless you are after the stock appearance, I'd give serious consideration to that Schmidt air box.  It seems to be very nice for the money.  Notice it's clearanced for a holley.
If you are looking for stock appearance, I doubt you will have hood clearance issues using a factory box like mine or Lorne's, especially if you don't need a spacer.
« Last Edit: February 28, 2009, 08:40:37 pm by eventhorizon66 »
Offline SUX2BU99
« Reply #22 on: March 14, 2009, 01:13:14 am »
That Spectre box is very interesting. I'm a big fan of ducted air inlet systems like any of those used on muscle cars and are performance-oriented rather than the usual choker setups like most cars had in the late 70s and 80s. The Spectre setup reminds me of a guy who had a 92 Dakota with an air cleaner like that but he routed the two hoses upward to a pair of small scoops that came off a Dart GT I think. Functional and simple. I'll have to find a pic of it and show the link. It was cool.
Offline 82Shortbed
« Reply #23 on: March 18, 2009, 02:30:59 pm »
I like that!  I may consider something like that on my next truck fo sho!
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline Just-speed
  • 84K10 350/700r4
« Reply #24 on: April 19, 2009, 06:51:47 am »
Guys if your intrested in the dual snorkel set-up and just want to buy it I should point out you can buy it from Summit. I have posted pics of my truck before and I have the dual set-up.  It does not cost that much.  Here is a pic of my engine with the dual set-up.  I will give you part number and such if you need.  Just ask.
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
« Reply #25 on: April 19, 2009, 11:45:01 am »
You mean this one?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SPE%2D9869&N=700+400068+4294756384+115&autoview=sku
http://www.jegs.com/i/Spectre/865/9869K/10002/-1
I considered that, but it was still more money than I wanted to spend and I didn't want more chrome/polished aluminum under the hood (I'll eventually go back to black valve covers).  The best bang for the buck ram air box out there, that I've found, is this one:
http://www.schmidtmotorworks.com/ram_air.htm
« Last Edit: April 19, 2009, 12:34:02 pm by eventhorizon66 »
Offline Just-speed
  • 84K10 350/700r4
« Reply #26 on: April 19, 2009, 11:58:22 am »
You mean this one?
I considered that, but it was still more money than I wanted to spend and I didn't want more chrome/polished aluminum under the hood (I'll eventually go back to black valve covers).  The best bang for the buck ram air box out there that I've found is this one:
  Very nice. Wish I would have known about the one you found.  Nice price.  I might go ahead and order it anyway.
« Reply #27 on: April 19, 2009, 12:33:35 pm »
If I had known about it before making my own, I probably would have gotten it.
« Reply #28 on: October 06, 2009, 10:44:36 pm »
eventhorizon,,,,,,what size filter fits inside?
« Reply #29 on: October 07, 2009, 08:38:42 am »
12" x 3.5"
KN filter #E-1500
It's a standard small block TBI truck filter.
