Author Topic: How do i lean back the fuel?  (Read 11238 times)
Offline Skunksmash
« on: August 12, 2008, 02:05:51 am »
Is there a way to manually lean back the fuel on a TBI engine? Specifically an '87 5.7 liter TBI engine. I know that the O2 sensor detects the ammount of oxygen and adjusts the fuel accordingly, but i am looking for a manual way to lean the fuel back as far as i can. Is there some screw or something somewhere on the TBI unit much like on the carbs that came before it?
Re: How do i lean back the fuel?
« Reply #1 on: August 12, 2008, 08:22:26 am »
Why would you want to do that? Are you hoping to burn a valve or ruin your engine?
Offline eventhorizon66
« Reply #2 on: August 12, 2008, 11:48:09 am »
Trust in your ECU to deliver the best A/F ratio, unless something is wrong and it's not running right.  Are you hoping to do this as a fuel saving measure?  Or is it running pig rich and fouling plugs?
'85 C10 SWB 350 700R4 TKO600
Offline Unofficial
« Reply #3 on: August 12, 2008, 12:52:37 pm »
No offense, but if you're willing to risk ruining your engine by forcing it to run lean to save gas, you're better off driving something with better fuel economy to start with.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Offline Skunksmash
« Reply #4 on: August 12, 2008, 03:32:01 pm »
No. I just need a way to lean it back so that when i am ready, i can install my HHO generator on the truck. Unless you lean back the fuel on any vehicle using an HHO generator, you will gain nothing. The idea is to supplement the gasoline with hydroxy gas, and you cant do that while spraying as much gasoline as you always used to. Not only that, if it can (which is almost always) the 02 sensor will detect that extra oxygen and the computer will then increase the fuel being sprayed. Which of course is counter productive. This is kinda also the reason i had the gas mileage thread. I thought maybe if i could squeeze out a few more MPG out the engine normally and without the generator, then the results with the generator on the truck would be maximized. A friend of mine uses an HHO generator and achieves 59 MPG highway in his Geo. Now granted thats a 4 banger, but it was never meant to do that well. So i figure even these old trucks would see a good increase in MPG. Might be able to get it up to around 25-30MPG. It's only around $100 to build the generator so it would completely pay for itself in about 2 tanks of gas. Every day after that is just savings.
« Reply #5 on: August 12, 2008, 04:44:56 pm »
What kind of Geo?  The Geo Metro in 1989 was a 3 cylinder that was Rated for 51MPG on the 43MPG in the city.  It WAS designed for high mileage like all the other Geo's.
Offline Skunksmash
« Reply #6 on: August 12, 2008, 05:14:45 pm »
Oh no lol, this car could never get even close to that without a generator. Its a newer geo tracker, but im not sure as to the exact year. I will have to ask him that. So uh, anyone know how to lean out the fuel on a TBI?
« Last Edit: August 13, 2008, 02:47:42 pm by Skunksmash »
Offline TexasRed
« Reply #7 on: August 13, 2008, 09:34:57 pm »
You might be better off trying to use megasquirt.
Offline Skunksmash
« Reply #8 on: August 13, 2008, 10:19:06 pm »
Or a carburetor.
Offline TexasRed
« Reply #9 on: August 13, 2008, 10:38:02 pm »
That would be the easiest way.
Offline FlatBroke
« Reply #10 on: August 14, 2008, 07:42:35 am »
Hang on Skunksmash....Let me see if I can e-mail you a link from another site.....
Be right back.
It's not the tires screaming, It's the asphalt
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7217.0
Offline FlatBroke
« Reply #11 on: August 14, 2008, 07:48:17 am »
http://mileagemaker.us/efieplans.pdf
Se if that thing looks like it will accomplish what you want to do. Let me know if I can be any further help.
« Reply #12 on: August 14, 2008, 12:39:58 pm »
Or a carburetor.
Let me get this straight, you want to go from TBI to carb to improve fuel efficiency.  This ought to be good.  Keep us posted on how it works out.
« Reply #13 on: August 14, 2008, 12:51:36 pm »
I would like to see what this is all about.  I ran my 4.3L last night (push started it) carb is in excellent shape which I will put on my 350 when I transplant it and try this ad.  I am planning on looking at this setup hard just to be different.
« Reply #14 on: August 14, 2008, 03:24:50 pm »
oh boy.
