Author Topic: windshield is stuck  (Read 10316 times)
Offline hotrod24
windshield is stuck
« on: August 20, 2008, 04:16:32 pm »
hey what is the easiest way to get a windshield out without the wire because mine is really in there
1978 pontiac grand prix...
Re: windshield is stuck
« Reply #1 on: August 20, 2008, 04:31:31 pm »
Front or rear?  The front you pull the locking strip out and then roll the glass out.  You shouldn't need a wire if it has never been removed.
Offline ccz145a
« Reply #2 on: August 20, 2008, 04:36:37 pm »
Same way for the rear glass, if it has never been out.
If it has butyl sealant and you are not reusing the gaskets, then cut the rubber with a stout blade. Hold the blade along/against the glass and cut under the lip. Be careful!
Offline hotrod24
« Reply #3 on: August 20, 2008, 04:59:17 pm »
it is the front and it has some kind of glue holding it in there and i dont know if it has been took out before
Offline ccz145a
« Reply #4 on: August 20, 2008, 05:42:41 pm »
the windshield had no glue or sealant from the factory. Vile had quoted a document recently that butyl be used for new installs to keep the glass from poping out.
if the stuff that's in there is still gooey, then it is most likely butyl. ought to come out without cutting or string, start in the corner with firm steady pressure pushing from the inside.
Offline hotrod24
« Reply #5 on: August 20, 2008, 06:08:35 pm »
yea i tryed to push it out and it want budge but i took a knife and got it lose a little bit but not enough but there is some kind of glue under the class.
« Reply #6 on: August 20, 2008, 06:16:08 pm »
here's what I use
windshield knife
Offline hotrod24
« Reply #7 on: August 20, 2008, 06:27:13 pm »
ok thanks vile
Offline 80stepsideguy
« Reply #8 on: August 21, 2008, 12:08:30 am »
Did you remove that middle seal? You need to remove that seal in the center before you can take the windshield out. It should come out with ease just push harder and it should come out, if your gonna go full resto then dont be bashful if you crack it your gonna want to put a new 1 in anyways.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline hotrod24
« Reply #9 on: August 21, 2008, 02:38:07 pm »
yea i took the seal out and it want come out but i did not push very hard so that might be it oh and i did take a screw driver and put in the inside of the windshield and pushed out and it moved a little bit so it is in there pretty good.
Offline hotrod24
« Reply #10 on: August 21, 2008, 07:57:04 pm »
ok i got it i cut part of the gasket so i could get it out better and i did crack it in some places but i am going to get a new anyway and all i had was a razer blade and a screw driver and my two hands besides that it was my frist time so that makes up for the sloppy job ;D but i was right it was rusty so i am glad that i took it out.
                  is there supposed to be a hole in this area it is on the left
« Last Edit: September 23, 2008, 07:46:51 pm by hotrod24 »
« Reply #11 on: August 22, 2008, 01:38:52 pm »
Are you talking about the drain hole for the glass?
Offline hotrod24
« Reply #12 on: August 22, 2008, 02:12:10 pm »
thats it because there is one on both sides thanks chris
« Last Edit: August 22, 2008, 02:19:57 pm by hotrod24 »
« Reply #13 on: August 22, 2008, 02:37:59 pm »
yes, there should be one on each side.  If they aren't cleaned out, the whole area could be rotted.
« Reply #14 on: August 22, 2008, 09:14:48 pm »
Thats what happened to my 1st  cab,
the p/o had the windshield replaced and they plugged up them holes with silicone and it rotted the entire lower portion under the windshield.I had to totally rebuild it and it was ok but the cab needed replacing so make sure them holes ALWAYS stay clear.
thanks
pat
