Author Topic: Electric Fan Feedback wanted  (Read 17118 times)
« on: August 25, 2008, 09:44:52 pm »
I generally buy Flex-a-Lite when it comes to electric fans, but I ran across Perma-cool the other day, and it is designed to fit our trucks with the existing mounting points, which I like.
I just upgraded the radiator to a Proliance 433730 2 row radiator
http://www.pliii.com/catalog?searcher%5Bproliance_part%5D=433730&search_proliance_parts=SEARCH
I am looking at these fans:
http://perma-cool.com/Catalog/Cat_page18-1.html
and
http://www.flex-a-lite.com/auto/html/27inch-electric.html
Anyone have any info on the Perma-Cool?
This is the radiator in my 87 now.
Offline Dragon
Re: Electric Fan Feedback wanted
« Reply #1 on: August 26, 2008, 03:04:05 pm »
I grew up with my Father and Grandfather both using flexlite fans for years... If I am able to do an electric conversion, I will probably go with them since they are local, and I can get the parts quicker.... I have heard nothing but high remarks about various Perma-cool products(through several magazine articles over the years and friends that have used them), so I have been wanting to try their remote oil & trans filters/coolers...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline eventhorizon66
« Reply #2 on: August 26, 2008, 04:48:26 pm »
I looked at that permacool unit, but the price scared me off.  When I'm ready for electric fans I'll buy a pair of separate SPAL 14" fans and make my own shroud out of either sheet aluminum (riveted) or fiberglass.
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: August 26, 2008, 05:46:10 pm »
I've also looked into buying their close to drop in set-up for our trucks and thought that the price vs the benefits wasn't worth it. I would just make my own or stick one inside your existing shroud.
« Reply #4 on: August 26, 2008, 06:02:16 pm »
The Factory shroud won't work, the radiator is that much larger. I am trying to do the upgrades for the future Twins.
I am entertaining the idea of building my own shroud and my buddy has a TIG welder....
Right now, I can't drive it because of no shroud.
« Reply #5 on: August 26, 2008, 07:18:20 pm »
I don't understand, it sure looks like the same size radiator in my 85 with the 7.4L.  I have the same upper mounting that the shroud bolts to at top.
« Reply #6 on: August 26, 2008, 07:35:27 pm »
I cut and modified the upper brackets to hold the radiator in.
« Reply #7 on: August 26, 2008, 07:38:02 pm »
How about we design a nice drop in for our trucks and you can sell em here.
« Reply #8 on: August 26, 2008, 07:44:11 pm »
hehehe, that is kinda where I was going with my previous post.
Ok, what are the specs we wnat to work with?
« Reply #9 on: August 26, 2008, 08:39:12 pm »
well there is essentially what? 3 different mounting options?
Offline mudtoy
« Reply #10 on: August 26, 2008, 10:06:56 pm »
I had a 4.3 in a Toyota couldn't cool it with aftermarket electric fan or a belt driven flex fan and it had a griffin aluminum radiator. Done some research on line found people were using a two speed  Taurus fan. You can pick them up at junk yards fairly cheap and the shroud I made out of aluminum diamond plate. I live in Florida and I could run the ac while mud ridding and it would never run hot. I had the fan wired to a toggle switch for the fan speed so if it started to run warm I could switch the fan from low to high. I plan on on running two Taurus fans on my 454.
DAV Life time Member  US Army served Proud
« Reply #11 on: August 26, 2008, 10:13:46 pm »
The Flex-a-lites are dual speed, they are 60/100%.
Yes I think there were 3.  The radiators physical size was the same though.
Do we want to focus on factory, or?
« Last Edit: August 26, 2008, 10:18:14 pm by Captkaos »
« Reply #12 on: August 27, 2008, 11:54:42 am »
I like where this is going.
Offline JJSZABO
« Reply #13 on: September 04, 2008, 11:24:50 am »
DITTO!!
Jeff
86 Chevy C-10
350, TH400
Offline mp76k10
« Reply #14 on: September 04, 2008, 02:31:58 pm »
I'd be in for the purchase of a drop in...
truck?  what truck?
