Author Topic: Question for Vile  (Read 6401 times)
Question for Vile
« on: April 01, 2007, 09:31:00 am »
Cant seem to find the post but I am thinking you said you used to work on Junks, I mean Jeeps. If I had any questions to shoot them your way? Have a plug that comes out of the wire harness from the fuel injection wires trunk also goes to one of the four O2 sensors. It has four wires, 1 black, 1 black w/ yellow stripe, 1 tan w/ white stripe, 1 purple w/ orange stripe. Got a few pics. too.
Edited by: Blazin at: 4/1/07 10:58 am
Offline DnStClr
Re: Question for Vile
« Reply #1 on: April 01, 2007, 09:55:00 am »
Harold, does that thing have an ignition module on the wheelwell behind the coolant reservoir?
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
« Reply #2 on: April 01, 2007, 11:57:00 am »
It might but this wire is on the drivers side and not even close to long enough to reach behind the coolant reservoir. It runs I drove it about some yesterday. The check engine light is on I am suspecting this might be the cause.
« Reply #3 on: April 01, 2007, 10:02:00 pm »
I'll take some pics tomorrow and post them so you can see how to run that wire. I just saw this post now and it's late here. But I'll get that to you asap. What year is that btw?
« Reply #4 on: April 01, 2007, 10:21:00 pm »
Its a 2000. I looked but don't seem to see where it plugs into. If I knew that I could figure out how it runs.
Edited by: Blazin at: 4/1/07 9:21 pm
« Reply #5 on: April 02, 2007, 06:17:00 pm »
Sorry I didn't get a chance to take a pic but it goes behind the power steering pum bracket and down to the oxygen sensor.
« Reply #6 on: April 02, 2007, 09:22:00 pm »
« Reply #7 on: April 03, 2007, 06:26:00 am »
One of the 4 oxygen sensors! I will take a look, I could have sworn I pluged all of them in, But you never know. I started it and it wasn't charging when I took a closer look I had forgot to plug the field wires into the altinator. Thanks.
« Reply #8 on: April 03, 2007, 10:38:00 pm »
Thats what it was, thanks. Will the codes clear from this by disconecting the battery or do I need to clear it with the scanner?
« Reply #9 on: April 04, 2007, 03:02:00 pm »
You need to clear it with the scan tool.
« Reply #10 on: April 05, 2007, 05:33:00 am »
Yes asked my buddy yesterday that is good with computer diognostic stuff. He is going to do it for me some time next week. Thank you for all the help.
Edited by: Blazin at: 4/5/07 4:33 am
« Reply #11 on: April 05, 2007, 08:47:00 pm »
Took it today he cleared two codes, the down stream O2 sensor, and the altinator. I forgot to plug it in until a little ways into my test drive.
