Body, Glass & Paint
replacement cab mounts
Topic: replacement cab mounts (Read 25227 times)
chrpmaster
September 15, 2008, 02:32:26 pm »
I have a 76 C10 standard cab long bed. I was having problems with the door being out of alignment and not closing well. I had a buddy help me try to get it back into alignment. He noticed that the problem was that all the cab mounts were rusted thru. Are replacement cab mounts still available? If not can I just fab up some mounts and weld them on or is there something I am missing? Do I need an original rubber spacer or can I just use some old rubber floor mats or chunks from an old tire etc.
Thanks
Andy
Re: replacement cab mounts
September 15, 2008, 04:09:16 pm »
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?
Blazin
Blazin new trails!
September 15, 2008, 10:04:15 pm »
The body mounts are rusted through. Rusted through the frame mount? rusted through the bottom of the cab? The body mounts are Mostly rubber with a thick steel top, and shank. The bottom washers have a tendency to rust out around the bolt, fall off, and then the lower half of the mount rubber falls off.
If it is the mount itself then yes you need new mounts. You cant cave man a chunk of tire of something in. If the frame mount is rusted out around the mount, then you need to do some welding. If it the floor support then you also need to do some welding.
chrpmaster
September 16, 2008, 09:23:52 am »
Quote from: VileZambonie on September 15, 2008, 04:09:16 pm
Mabye I'm blind but I don't see the cab mounts. I need the ones right behind the front tires.
Yes I need the frame mounts. The part on the cab that the frame mounts bolts onto is fine.
Thanks
Andy
September 16, 2008, 10:13:47 am »
First, what are you talking about when you say cab mounts?
To me a Cab mount is the steel section that is welded to the cab where the body mount goes.
A frame mount is the steel support that is welded to the frame where the cab sits and the mount seperates it.
The body mount is the rubber ( or polyurethane) that goes between the cab mount and the frame mount.
Body mounts can be found here for 73-80 trucks:
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-909&Category_Code=C1
chrpmaster
September 16, 2008, 08:49:19 pm »
Sorry is I said it wrong but I need the mounts that are welded to the frame and the cab mounts bolt onto. The one you had in your picture looks like just the rubber bushing and bolt that connects the cab mount to the frame mount.
Thanks
Andy
hotrod24
September 16, 2008, 09:04:57 pm »
man you are going to have to find a parts truck or a junk yard to find that or do what blazin said do some welding good luck
Last Edit: September 16, 2008, 09:41:28 pm by hotrod24
1978 pontiac grand prix...
86 chevy silverado
September 16, 2008, 09:07:59 pm »
Is this what your looking for?
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-309&Category_Code=C1
chrpmaster
September 17, 2008, 09:45:27 am »
Hmmm. I think there is some kind of bolt hole needed so the body mount can be used. I will have to check with my buddy who has a steel fab shop and see what he can whip up.
Thanks for all your help guys. I think I will need to do some fabrication then use new body mounts to connect it all together. I was hoping to find some replacement frame mounts for sale somewhere that I could weld on.
Andy
September 17, 2008, 10:23:51 am »
click here
September 17, 2008, 10:25:47 am »
Andy, If it is the pieces that weld to the frame, now bad are they? (gotta pic) You can probably get them from a donor for next to nothing, if they are completely shot, or you could do like Blazin suggested and weld on it....
Or you can... Wel, Vile beat me to it.
The piece 86 Chevy Silverado posted is the piece that goes to the cab floor.
JJSZABO
September 17, 2008, 11:52:37 am »
Quote from: VileZambonie on September 17, 2008, 10:23:51 am
click here
WOW - way to go Vile
There you go Andy - and only 20.00 apiece. GREAT find!!
Jeff
86 Chevy C-10
350, TH400
86 chevy silverado
Reply #12 on:
September 17, 2008, 03:13:11 pm »
A pic I shot just for you showing both pieces. This is an '86, your bushing will be different.
chrpmaster
Reply #13 on:
September 19, 2008, 12:36:15 pm »
Looks like Vile is my new friend.
Thats exactly what I need so will order them and have them welded on. I will check the bushings and mounting bolts and will probably need to replace them also.
Thanks everyone for your help with this. I will post pics when i get the new parts welded on.
Andy
ccz145a
Reply #14 on:
September 19, 2008, 02:34:39 pm »
You could weld, but the holes are there and you could use grade 8 bolts.
Body, Glass & Paint
