Author Topic: Vacuum Leak  (Read 3422 times)
Offline Unofficial
Vacuum Leak
« on: October 20, 2008, 10:21:17 pm »
It seems like almost ever since I put in my rebuilt 350, I've had this hissing sound. I replaced the valve covers, so my PCV setup got changed, and now I have a big unused nipple coming out of the TBI spacer ring that the air filter sits on. I got a new spacer without the nipple, and I still have that really bad hissing. I figured I must have some kind of vacuum leak, but I don't know where to start. Is there any special technique or do I just look at every single vacuum line?
Also, I've noticed that sometimes, if I take off from a stop sign or a light, I'll lose all power and it will feel like I'm taking off in too high of a gear. The engine bogs down and I could floor it and it would just chug. Do you guys think a vacuum leak would be associated with this problem, it's getting pretty annoying. Thanks for any help.  :)
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Re: Vacuum Leak
« Reply #1 on: October 20, 2008, 10:24:57 pm »
Offline gerardo0367
  • hi all
Re: Vacuum Leak
« Reply #2 on: October 20, 2008, 10:45:20 pm »
Check the butterfly shafts on the base of the carb i had one that leaked and it had a hissing sound also from worn shafts and or bushings later
All Man wheres my wallet and my keys I wont try that again
