Author Topic: headlight switch harness problem  (Read 4512 times)
Offline biodiesel84
« on: October 30, 2008, 09:10:20 pm »
well, I melted the plug a little on the back of the headlight switch...and I don't want to hack it up and just splice a new plug on the harness, so my question is what all is attached to the harness that has the headlight switch plug on it....thanks...
Chuck.
Re: headlight switch harness problem
« Reply #1 on: October 31, 2008, 10:01:13 am »
The whole underhood lighting wiring harness.
Offline hotrod24
« Reply #2 on: November 01, 2008, 12:23:35 am »
this is a good way take the connectors with the wires out of the head light plug and go to a junk yard and get a new plug for the head light switch it is easy just take the plug for the head lights and take a little screw driver and push the little metal peace in and it will come out then you will not have to cut any wires.
               this is the little peice with the arrow that you push in but make
                         sure before you put it back you pull it back up.
                                this is where you put the screw driver
« Last Edit: November 04, 2008, 04:14:39 pm by hotrod24 »
1978 pontiac grand prix...
Offline biodiesel84
« Reply #3 on: November 05, 2008, 06:28:56 pm »
thanks for the tip...now I just need to find a plug...:D
Chuck
Offline hotrod24
« Reply #4 on: November 05, 2008, 06:37:35 pm »
no problem man
