Cleaned IAC and Got A code 42.
Topic: Cleaned IAC and Got A code 42. (Read 4499 times)
DnStClr
November 02, 2008, 08:24:04 pm »
1987 Silverado 350 tbi- My idle stays high after it starts and warms up. I haven't put my tach on it yet. I removed and cleaned the IAC and it didn't help the idle, but it started throwing a 42 code.(EST) When I disconnected the battery B+ and reconnected it, the code went away so I guess the spark timing is ok. What caused the code? Is it normal after removing the IAC?
Don
87 Chevy Silverado
Re: Cleaned IAC and Got A code 42.
November 03, 2008, 01:47:28 pm »
I would drive it to see if the code comes back.
November 03, 2008, 03:34:30 pm »
You should remove the B- not the B+. It could very well have caused an eroneous code. Spray some carb clean under the TBI and see if it effects the idle.
DnStClr
November 06, 2008, 10:22:28 am »
It hasn't returned this week so far. No change in idle when carb cleaner sprayed.
Don
87 Chevy Silverado
Blue 82
November 09, 2008, 07:14:08 pm »
I had a sticking TPS switch cause the same exact malfunction (hi idle)
Cleaned the IAC, checked for vacuum leaks etc, nothing....
it's was acting up for a month or so, on and off
the light finally came on (code 22)
Replaced the TPS and all is fine
November 10, 2008, 01:32:08 pm »
Check the TPS as suggested. If it checks out ok replace the iac motor.
