Oil press. unit
Topic: Oil press. unit (Read 3377 times)
shankbonanza
1980 Chevy K10 Bonanza 350/th350/np205/12bolt rear
Oil press. unit
November 12, 2008, 03:24:20 pm »
I was installin my detent cable on my 1980 chevy 1/2 ton 350/th350 and when I was installin it back on the carb I accidentally knocked off the oil pressure sending unit? I believe and when I did this the 45degree connector (to get around distributor) cracked off in the block or manifold. I was wondering your thoughts on pulling that out and gettin a new connector? maybe an easy out? what are your ideas? Thanks guys
dumbucket1
Too Many Trucks
Coal Hauler
Re: Oil press. unit
November 12, 2008, 03:49:50 pm »
Ive done this a few times. I just tapped in a screw driver in it and screwed it out.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: Oil press. unit
November 12, 2008, 07:58:12 pm »
it is hollow, so an extractor won't have any problem gettin it out.
Also, on my 79, i don't have an angle on it to get around the distributor. Kind of strange, unless your intake isn't stock or something.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
Oil press. unit
