73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: Maintenanceman on March 03, 2009, 11:19:43 am
Title: Gauge Pods
Post by: Maintenanceman on March 03, 2009, 11:19:43 am
Anybody know where to get A pillar gauge pods for a 85 Silverado? heck, do they even make them?
TIA,
Ben
Title: Re: Gauge Pods
Post by: Captkaos on March 03, 2009, 11:22:10 am
Don't make them.  It is on my list for getting them though... (long list)
Post by: Maintenanceman on March 03, 2009, 11:26:04 am
that sucks. Im really wanting to get my tachometer off of my steering column but still have it in plain sight Suggestions or ideas?
Post by: werewolfx13 on March 03, 2009, 11:31:49 am
make your own out of fiberglass.
Post by: Maintenanceman on March 03, 2009, 11:34:49 am
thought about that but I dont know the first thing about 'glassin. Guess I need to do some research
Post by: zieg85 on March 03, 2009, 11:52:04 am
I don't remember where I saw it but there is an aftermarket stock appearing tach "kit" that replaces the fuel gauge and the fuel gauge is moved to where the blank/clock position is at, lower left.  I am thinking it was on EBay where I saw it.
Post by: SUX2BU99 on March 03, 2009, 03:02:00 pm
I put an Auto Meter tach in my truck and I mounted to the underside of the a-pillar. I used the housing it came with and bought an adjustable mount that Auto Meter sells seperately that I think is meant for use with roll bars (has a rounded contact point to mate wtih rounded surfaces like a roll bar). It worked out well. The only thing I can complain about is it bounces around a little bit since it's hanging from the a-pillar and my springs are rough. Overall though I think it's a clean spot to put it in. Better than the typical steering column or dash mount IMO.
Post by: Maintenanceman on March 03, 2009, 11:36:58 pm
pics?
Post by: 82ChebySWB on March 04, 2009, 06:04:24 am
I too would like to have a 2-3 gauge pod for the pillar.....but outside of glassing one...that's it. You'd think with how popular these trucks have been....and thier increase in desire even now that autometer would tae notice and build a pod.
I've got an Autometer 5" C2 Cobalt pedestal mount tach in my truck. I had it mounted previously on the pillar....but had to unbolt it and ship it back to Autometer for repair. I haven't reinstalled it just yet....because I need to dye the trim and door panels in my truck first.
I hope to have the interior dye work done within a couple weeks......when I get it done I'll take some fresh pics with the tach reinstalled
Post by: werewolfx13 on March 04, 2009, 06:38:54 pm
I suppose I could make a replacement A pillar w/ built in pods sometime this summer and do a write-up..Glassing is pretty easy, just time consuming and messy. If I do get a chance, if I make it for a tach, it'll be for a sunpro supertach II, since thats what I'm using right now.
Post by: Dragon on March 05, 2009, 01:33:13 pm
Not to step on anyones toes, but I'm a Bit Lazy when it comes to getting too drawn out on things....
http://store.summitracing.com/egnsearch.asp?searchinresults=false&y=0&N=700+115&Ntk=KeywordSearch&DDS=1&Ntt=Universal+Pillar+Guage+Pod&x=0
Universals get you there, and then even a Novice can blend them into their pillars if so chosen....
Post by: werewolfx13 on March 05, 2009, 09:06:21 pm
I played around with a set of those once, they're generally ABS plastic, I don't remember if the A pillar trim on these trucks is ABS or not..if it is, then mixing up some ABS sludge would work pretty well, but blending ABS takes some practice and patience.
Post by: 82ChebySWB on March 06, 2009, 05:59:47 am
That's kinda my fear about those pods. I want something that matches the factory look of the pillar. I think that I'll play around with this project in a couple months and see what I learn/teach myself about building a pillar pod. ;D
Post by: Stewart G Griffin on March 06, 2009, 08:09:26 am
The only other thing(s) i can suggest is, and i apologize because i have no pictures so we'll have to use our imaginations on this one, is if you can visuallize the rear view mirror's base attachment thing--in other words everything except the mirror it self, but the "arms" and pivot balls etc.
If you can visualize putting the tach/gauge mount where the mirror would normally go, then you can mount this gauge virtually anywhere without any drilling and using the glue makes it pretty secure.  You can still have the tach right in front of you but off the column and not cobbled to the dash.  i did get this idea from another 73-87ian, but i can't find the picture.
The second idea, which i'm probably going to do as soon as i get my act together and get the truck running right again is to use the overhead bolt in console idea and to mount the gauges off of this console because i just can't drill holes into the dash;  i want to keep everything stock.
i don't want to give a link to it as i don't think Chris would dig that, but there is a company that makes one for the 73-87's and it's bolt in.  i guess if you really want to know, we could go to PM or email.
By the way, if anyone comes up with a good quality pillar gauge pod for the 73-87 series, i'm buying it.
i think as a business idea, anyone who does this will get all the marbles ( or at least some of them).
Post by: SmokeShow on February 26, 2010, 12:28:03 pm
Haven't some had success using an a-pillar pod made for a 91-93 Dodge in the 73-87 GM?  It's not perfect because it's obviously not made for it but the pics I remember seeing, it was close enough for anything short of a show quality truck.
C-ya
Post by: Armor on February 26, 2010, 12:41:55 pm
i used a small tach and drilled a hole in the cluster where the blank was and put it there, you dont even notice its not stock will you see the white needle and better lighting lol
Post by: SUX2BU99 on March 03, 2010, 10:35:42 am
pics?
I got lots of video files showing my tach but no pics   ???  I don't think we can upload video files here.
You can kinda see it here but I need to just take a pic of it.
Post by: Skunksmash on March 03, 2010, 05:06:35 pm
I'd buy the heck out of one if it were priced reasonably.
Post by: Captkaos on March 03, 2010, 08:19:16 pm
Is it on Youtube?  You can link it here.
Post by: SUX2BU99 on March 30, 2010, 12:23:53 pm
I took a pic of my setup:
Post by: Maintenanceman on May 31, 2010, 09:30:08 pm
C-ya
 can anybody back that up?
Post by: Captkaos on June 01, 2010, 11:17:42 am
I have seen them and someone on here has them.  They look ok.
Post by: Maintenanceman on June 01, 2010, 04:20:26 pm
Id Like to see pics if anybody knows who has them
