73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 84chevysilverado on May 09, 2009, 11:10:00 am
Title: electrical problem
Post by: 84chevysilverado on May 09, 2009, 11:10:00 am
I have an signal problem here is what happened. signals, reverse and brake lights all worked perfect untill i hooked up my subs now sometimes the right interior signal aroow light flashes with the bass. I have no signals what so ever and no reverse lights but my brake lights work and my hazzards do to. all lights come on when i turn on the lights. I checked all the fuses and there all good. I also changed the flasher because I thought that was the problem. Im dumb founded as to what it could be. need help bad thanks marc ???
Title: Re: electrical problem
Post by: levisjohnson on May 09, 2009, 11:50:35 am
Have you disconnected the subs to see if that corrects the problem?  How did you wire it?
Post by: VileZambonie on May 09, 2009, 01:39:45 pm
Check your ground connections first. Where did you tap your power supply for your radio and amp?
Post by: 84chevysilverado on May 09, 2009, 01:56:42 pm
yes i have unplugged everything and still nothing. this is how i wired the subs I have a power wire comming strait from the battery to the amp. Then i have a ground wire from the amp to the seat bracket. I still have the stock radio which isnt hooked up to the subs. What i do is plug my ipod into the sub and listin to music that way. any ideas... ???
Post by: choptop on May 09, 2009, 06:43:22 pm
I would definately recheck the grounds. Make sure you have a ground from the block to the firewall, battery to block, battery to fender,and make sure the ground to the seat bracket is good and clean. Bare metal is prefered.
Post by: 84chevysilverado on May 11, 2009, 01:53:21 pm
checked all gounds last night that are for the signals. Like i said before the hazzards work, so do brake lights and reverse lights. Put new flasher in. still anyone got any ideas? ???
Post by: VileZambonie on May 11, 2009, 02:13:42 pm
