Author Topic: electrical problem  (Read 5097 times)
Offline 84chevysilverado
electrical problem
« on: May 09, 2009, 11:10:00 am »
I have an signal problem here is what happened. signals, reverse and brake lights all worked perfect untill i hooked up my subs now sometimes the right interior signal aroow light flashes with the bass. I have no signals what so ever and no reverse lights but my brake lights work and my hazzards do to. all lights come on when i turn on the lights. I checked all the fuses and there all good. I also changed the flasher because I thought that was the problem. Im dumb founded as to what it could be. need help bad thanks marc ???
Offline levisjohnson
Re: electrical problem
« Reply #1 on: May 09, 2009, 11:50:35 am »
Have you disconnected the subs to see if that corrects the problem?  How did you wire it?
Levis
88 6.2L Diesel 3+3 3/4 ton
« Reply #2 on: May 09, 2009, 01:39:45 pm »
Check your ground connections first. Where did you tap your power supply for your radio and amp?
« Reply #3 on: May 09, 2009, 01:56:42 pm »
yes i have unplugged everything and still nothing. this is how i wired the subs I have a power wire comming strait from the battery to the amp. Then i have a ground wire from the amp to the seat bracket. I still have the stock radio which isnt hooked up to the subs. What i do is plug my ipod into the sub and listin to music that way. any ideas... ???
« Reply #4 on: May 09, 2009, 06:43:22 pm »
I would definately recheck the grounds. Make sure you have a ground from the block to the firewall, battery to block, battery to fender,and make sure the ground to the seat bracket is good and clean. Bare metal is prefered.
« Reply #5 on: May 11, 2009, 01:53:21 pm »
checked all gounds last night that are for the signals. Like i said before the hazzards work, so do brake lights and reverse lights. Put new flasher in. still anyone got any ideas? ???
« Reply #6 on: May 11, 2009, 02:13:42 pm »
