73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: JJSZABO on April 14, 2008, 11:29:20 am
Title: Two steps forward, Five backward
Post by: JJSZABO on April 14, 2008, 11:29:20 am
After working on the truck this weekend, I've taken five steps backward >:(  ARGHHHHH
I noticed brake fluid on the floor below the proportioning valve.  I looked could not find any leaks.  I had my son step on the brake pedal and fluid came oozzzing from the black plug on the valve.  I installed an entire new brake system over nine months ago and had it blead before this arrived.  I called inlinetube where I bought the valve and they will stand behind the product - but I have to send it back so they can verify it has gone bad.  I am not mad at them - just mad in general because I have to redue this part of the brake system AGAIN.  So, when I remove the proportioning valve and ship it back, brake fluid will drip out and eventually empty the master cylinder.  Then when I get the new valve, I will have to remove the master cylinder to re bench bleed and reinstall it with the new prop. valve and rebleed the entire system.  I CANT SEEM TO WIN. :'( :'(
Another problem I found on Saturday.  My seatbelts.  My interior is finished, so I installed the bench seat.  Then I went to install the "new" seatbelts I bought off of ebay.  Black belts that were suppose to fit a 73-87 Chevy truck.  I never payed close attention to them until I had them installed and went to try them out.  The shoulder belt section would not latch into the middle lap belt section because the middle lap belt section was for a small latch and I had fat latches.   Now I have to replace my middle section with another middle section that will fit - back to searching and spending MORE money!!!!
Thanks for letting me rant
Jeff
Title: Re: Two steps forward, Five backward
Post by: VileZambonie on April 14, 2008, 12:13:56 pm
Get yourself a set of these
(http://www.thexton.com/vshop/..%5C_data%5Cdocs%5C319_200w.jpg)
and you can always grind down the edges on your buckle...
Post by: JJSZABO on April 14, 2008, 12:22:08 pm
Sorry Vile, but what are those pictured and are you serious about grinding the buckle?  If so, that might work ;D
Post by: VileZambonie on April 14, 2008, 12:30:43 pm
Yeah, I've done it with a customer of mines car. Of course I didn't give him a recipt for it but he was so fat he busted the belt buckle. Cheapest way out was to grab one out of a clunker I had laying around. It latched.
Those are transmission line plugs ( or any line for that matter) http://www.amazon.com/Thexton-312-Plug-All-Vacuum-Stoppers/dp/B000P9CP3Q
http://www.sjdiscounttools.com/thx319.html
Post by: JJSZABO on April 14, 2008, 01:24:04 pm
Thanks - That will help ;D
Post by: Blazin on April 14, 2008, 03:24:08 pm
I ground down buckles before on a race car window net.
Post by: zieg85 on April 14, 2008, 03:51:22 pm
Jeff
Go to Autozone and get some brass fittings and close off the ends when you remove the valve.  This will keep the master from draining.
Post by: JJSZABO on April 14, 2008, 07:13:16 pm
Thanks Guys ;D  I feel better now.
I couldn't find brass plugs that would fit so I clamped on a hose from one brake line to the next - no leaks.  I boxed up the prop valve and will mail back tomorrow.
I looked at the seatbelts and it looks as if the grinding of the fat latch will work.  I'll start with that tomorrow evening.
Thanks again guys  ;)
Post by: VileZambonie on April 14, 2008, 07:36:17 pm
good luck with it.
