Welcome
HI FROM NORTH CAROLINA
Topic: HI FROM NORTH CAROLINA (Read 14848 times)
3LM3ROM3RO
Re: HI FROM NORTH CAROLINA
Reply #15 on:
February 10, 2009, 03:06:13 pm »
thanks for the answer last time i did the cables one wire was touching the headers and it did burned and the spark plugs did have oil on almost all of them. the wire is still touching because the previous owner put some different kind of headers but its not burned yet.
choptop
Extended cab fanatic
Reply #16 on:
February 10, 2009, 06:18:52 pm »
If you pull the plugs again and find more oil on them then it may be time for new seals or valve guides. If you clean the plugs, and it clears up, then you know your on the right track with the heads needing work.
Blazin
Blazin new trails!
Reply #17 on:
February 10, 2009, 06:52:01 pm »
Welcome from New Hampshaa.
3LM3ROM3RO
Reply #18 on:
February 10, 2009, 09:57:56 pm »
yeah well i will check them out tomorrow and see what happens thanks for the help.
Welcome
