Author Topic: Help me pick a carburetor plz!  (Read 18084 times)
Offline 82Shortbed
Re: Help me pick a carburetor plz!
« Reply #15 on: February 22, 2009, 12:37:56 am »
I talked to a guy at work today.  He LOVES Edelbrock carbs, suggested me the 1406, just use more aggressive metering rods, he didn't remember the size then, step up to a .100 jet if it's still too lean in the primaries. and told me to drive it and enjoy it stating the 600 edelbrock is great for up to 400ci.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline jwag30
« Reply #16 on: February 23, 2009, 10:37:48 am »
the qjet was probaley 750cfm or bigger. i think the 750edelbrock but thats just my 2cents.
Speed is only a matter of money. How fast do you want to go!
Offline 82Shortbed
« Reply #17 on: February 27, 2009, 12:52:40 am »
So i called up Edelbrock Tech Support and spoke to a carburetor tech.... gave him the specs I have on here just I like gave you guys...expecting him to tell me a 1406...he tells me to use the 1412 800CFM!  I was like WTH, I asked him why such a big carb.  He was telling me with the vortec heads, the RPM Intake I have, and My cam's profile.  It's very similar to their RPM package and the 800cfm is the carb that goes on it....
'82 Custom Deluxe
Offline kiowamec
« Reply #18 on: March 04, 2009, 01:19:52 am »
The Quadrajet is the best street carb available.
Save your money and rebuild the Quadrajet and buy a wideband instead to set it up.
Offline TexasRed
« Reply #19 on: March 04, 2009, 08:39:16 pm »
That would be a wideband O2 sensor.
Offline Chevalade
« Reply #20 on: March 22, 2009, 12:35:13 pm »
An 800 is WAY to big for your app. Even with the extra flow of your intake and heads, I wouldn't go any bigger than a 650. I would go with the 600 personally. A smaller carb will give you a bit better mileage too I bet. I run a 600 on my 350 with performer intake and ported steel heads, and it is great. Good throttle response, and not half bad mileage.
Offline Just-speed
  • 84K10 350/700r4
« Reply #21 on: April 01, 2009, 09:27:49 am »
Dude.  Your set-up would be perfect with the 670cfm holley.  If you go with the 800 you will be returning it the very next day.
670 cfm is perfect.  Holley carbs have there pros and cons. Biggest Pro. Parts are always just down the street at the parts store.
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
