Author Topic: Pics of my 83 Step-Side Ladder bar Setup  (Read 19255 times)
Offline lincoln welder
  • wa-wa-wagon !
Re: Pics of my 83 Step-Side Ladder bar Setup
« Reply #15 on: March 29, 2009, 09:07:07 am »
Thanks byrd,I just hope mine ends up looking as trick as yours....Thats a cool piece! Thanks again to all you guys for the positive comments! Glad to be a part.
72' blazer 8" lift ZZ4 350
83' 2wd step side 489 BB
06' 3500 duramax
08' radio flyer 16" lift,ladder bars &custom interior.
  • wa-wa-wagon !
« Reply #16 on: April 11, 2009, 08:09:37 pm »
All back From Paint and  Powder coating.
06' 3500 duramax
Offline Stewart G Griffin
« Reply #17 on: April 12, 2009, 12:04:27 pm »
i'm wondering, when you welded the ladder bar to frame mounts, did you leave the stock suspension and rear axle in place so that everything would be square?  Or did you just measure from some point on the frame?
b) Could the rear axle be moved further rearward, to increase wheelbase (i think everyone knows where i am going with this) using this type of suspension?
Offline oldwhity
« Reply #18 on: April 12, 2009, 06:06:31 pm »
That lookin good! Man, are those meats going to fit inside the fenders?! I'm diggin it!
Rob G.
81 Chevy K20 4x4 LWB stepside
  • wa-wa-wagon !
« Reply #19 on: April 12, 2009, 07:01:43 pm »
Stew, I took the rear axle and suspension out completely and struck lines plum, square etc. then set up the 9".  I guess the axle could be moved back but not more than about an inch. Thanks Whitty,The tire demension o.s. to o.s. is 1 1/2 " wider than the stock 10 bolt with the factory rallys, so yes they will fit inside the fenders with a few alterations to the inside of the bed ofcourse . ::)
06' 3500 duramax
« Reply #20 on: April 13, 2009, 02:37:41 am »
Lincoln were about on the east coast are you at I'm in Henderson. and you said you about half way between Kent and DE line that what about the ruthsburg area?
