Members Rides
......Project never Done......
Topic: ......Project never Done...... (Read 41676 times)
flat black
Re: ......Project never Done......
Reply #30 on:
September 12, 2009, 12:52:54 pm »
I took a 1974 350 bored .040 over with eagle crank, comp cams, keith black 220 domes, bowtie angle plug heads with 2.055 valves, powermaster 4.0 hp starter dynoed at 453 hp......Sm 465/205 both rebuilt, new centerforce clutch, new slave and master.. Now 8inch front springs, skyjacker shocks, weld on and bolt on steering box brace, rebuilt d60, new bearings, seals, king pins, rotors, calipers, pads, detroit locker, ctm axle joints, skys crossover steering with trail gear hydro assist,ems steering box cap,ord greaseable poly bushings, energy suspention body, motor and trans mounts. Diy4x shackle flip in the rear with 4inch springs, greaseable bushings, new drive shafts with new u joints, ruffstuff disk brake brackets with new rotors, seals, calipers, hoses and pads, detroit locker with 456 gears, 670 truck avenger jetted and larger nozzles , runs mixed race gas and 93,headman 1 5/8 flow tubes, 3inch pipes with new flowmaster super 44s, 39.5 15 15 tsls on eaton 15x10s........ In the process now doing twin sticks on my np205 then smitty built 10,000 with dual optimas and a power master alt..
87OldYeller
Reply #31 on:
September 12, 2009, 01:50:40 pm »
That bed actually looks good on that truck. Never seen one that was actually done just heard it talked about.
http://i677.photobucket.com/albums/vv131/87OldYeller
Chevalade
Reply #32 on:
September 12, 2009, 02:42:19 pm »
Nice clean build. What did you go with for lift above the shackle flip? Hydro assist must be nice.
flat black
Reply #33 on:
September 12, 2009, 02:57:53 pm »
The bed fit real nice, i had a 2inch body lift and a 3inch, i used the 2 on the cab and the 3 on the bed. worked perfect. But i had to drill all new holes and fill in the old ones. It was trial and error, i think it came out good and doesnt line up too badly.....thanks
Hydro assist works good with the 60 locked, its real nice on the street. I did the west texas offroad pump mod, ems off road sold me the cap and tapped the other for 50.00. The cylinder, hoses and mounts are all from east coast gear supply.....(trail gear 2x8 and 2 3/8 hydralic hoses) works awesome turning 39.5s
Shackle flip is from diy4x with 6inch shackles, cleaned and painted the frame, then i used new 2inch trailmaster springs with out the overload and a zero rate(basicly a bolt in one inch block)....the height comes out to be 4inches plus the 4inch shackle flip, almost even with the 8inch superlift fronts....
devious
Reply #34 on:
September 12, 2009, 11:51:08 pm »
thats a good lookin truck man
flat black
Reply #35 on:
September 13, 2009, 07:53:48 am »
Thanks, guys
SUX2BU99
Reply #36 on:
September 14, 2009, 05:39:00 pm »
What brand of rear gears did you use?
treepete
Re: 83 stepside...(new pics)
Reply #37 on:
September 22, 2009, 06:17:57 pm »
Quote from: campcrf on July 18, 2009, 10:40:57 pm
now you just need some mean black roll bars for it.
yeah... giant lights or something.
Last Edit: September 23, 2009, 02:36:32 pm by Captkaos
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.
www.rccorral.com
flat black
Reply #38 on:
September 23, 2009, 05:55:46 am »
cant find a roll bar that fits the bed right and the gears are richmond, with the detroit locker...
Chevalade
Reply #39 on:
September 25, 2009, 12:02:58 am »
Please for the love of .....do not put a roll bar on it. Cage or exo it please.
flat black
Reply #40 on:
September 28, 2009, 07:18:20 am »
i was thinking a black toolbox and toneau.....im not that hardcore for an exo or even a cage
Members Rides
