Author Topic: At the track  (Read 15618 times)
Offline mike_hd1340
Re: At the track
« Reply #15 on: May 26, 2009, 04:39:06 pm »
The best I got was 1.58  average was 1.60 1.61
Offline HAULIN IT
Re: At the track
« Reply #16 on: May 26, 2009, 05:02:30 pm »
Hmmmm, Maybe you can check with tghoward1376 for some pointers about your traction problems...he went 1.54 60's with an one wheely peely & stock suspension ;)
Offline mike_hd1340
Re: At the track
« Reply #17 on: May 26, 2009, 06:04:52 pm »
I think he was spraying 175 shot off the line when he ran the 1.54 and broke doing it.  I've been getting 1.58-60 on motor.  If my trans did'nt break I think she would've been 1.4s  it hooked hard.  As soon as the left tire came back down is when it broke.
Offline tghoward1376
Re: At the track
« Reply #18 on: May 26, 2009, 07:57:57 pm »
not one wheel peel   my truck has a 3.73 geared 12 bolt that is welded up   lincoln locker   lol  was like that when i bought it  lol
Offline HAULIN IT
Re: At the track
« Reply #19 on: May 27, 2009, 07:47:42 am »
Tg, Ok, I got you & campcrf confused from your other post...all of the 3.73 & 4.56 talk was too much for my brain to keep on track.
  Also, I had a mess just like yours a few years ago. Right side, spring broke then the shock got bent, U-joint broke, yoke got chunked, muffler bent, ect. ect. Get the front of the spring held still & you should be good to go. Have Fun! Lorne
Offline HAULIN IT
Re: At the track
« Reply #20 on: May 28, 2009, 07:51:05 am »
Mike, Do you have any pictures of the launch? Is the Left side comming up way higher than the Right? Where that tranny is broken, I would think that is from the frame twisting...Left mount goes up, Right mount goes down & trans mount is stuck in the middle.
 Are planning to do a rollbar/cage? Are truck frames as far as twist goes goes, is pretty bad. I have a plan for a real slick anti-roll bar, but I'm not sure without some frame stiffening that it will work all that well, most likely just twist between the anti-roll bar & the engine area. The ultra bell should fix you up. Another option if this continues to be a problem  would be to go to a mid-plate, the combination of the engine & frame attached there seems to help each other.
My friend has a high 9 second '68 Camaro with a stock subframe (does have connectors & a 10 pt. cage). He broke a block up the lifter valley & a transmission that looked just like yours. This was with solid mounts & a urethane tranny mount...adding a mid-plate seems to have stopped the problems, the last couple years have been pretty good to him. My Two Cents, Lorne
« Last Edit: May 28, 2009, 08:31:38 am by HAULIN IT »
