Author Topic: Post your Differential pics for Identification  (Read 13825 times)
Re: Post your Differential pics for Identification
« Reply #15 on: June 05, 2009, 05:45:50 pm »
12bolts were never floating, only 14bolts.
A number of gears could be in it and it could or could not be a posi.  Pop the cover and you can find out both fast.  The ring/pinion count is stamped on the gears...
Offline pacu44
« Reply #16 on: June 07, 2009, 06:33:43 pm »
14 bolt full floater diff
I have the same rear differential... Is there a marking on it to tell me the gear ratio?
« Last Edit: June 07, 2009, 08:49:50 pm by Captkaos »
Offline 4x4orbust
« Reply #17 on: June 07, 2009, 08:40:15 pm »
which rear diff are you referring to?    i think capt said the ratio is stamped in the ring (have to pull the cover to read it)
