Author Topic: Headlight Conversion  (Read 25863 times)
Re: Headlight Conversion
« Reply #15 on: June 10, 2009, 10:09:42 pm »
It was on a 81-87 and they used the 88-99 light modules.  I looked but I cant find it...  He took alot of pics on it...
Offline Skunksmash
« Reply #16 on: June 11, 2009, 01:53:57 am »
It would be great if you could find a pic of that somehow, i would love to see it. Not that i would ever do it to my truck lol, but i would love to see how it turned out.
Offline wraprail
  • Supreme Member
« Reply #17 on: June 11, 2009, 04:40:13 am »
I once owned a 91 camaro that I installed 88-99 Chev truck composite headlight assembles into. They worked great. Made a frame out of half inch square tube to mount them. Thing is they have a lot of angle to the grill if you look at the front of an 88-up pickup and that you cant change or you cant adjust.  Worked on a camaro but on a flat front C-10??
« Last Edit: June 11, 2009, 04:49:11 am by wraprail »
"Abuse it till you lose it"
Offline modular93fox
« Reply #18 on: June 11, 2009, 08:41:44 pm »
Ive seen it done in person with the 96 style composit lights. looks ok, but the light beam is not going to be nice at all. the left beams will be pointed to the right, and the right beams will be pointed left when the housings are flush looking on the grille. the only hope you have is to seperate the lense from the base and mod the heck out of the base then re-glue it. the guy that did his swap lived with the crappy beam alignment and he used 4 bolts and washers to space it out from the core support.
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
