Author Topic: 83 short project  (Read 34682 times)
Offline GMCtruckinNDN
  • I'm Texan Cruiser
    • Native American & Cherokee Cultural Community
Re: 83 short project
« Reply #15 on: July 04, 2009, 05:54:25 pm »
Your Truck looks great!
I wondering your Truck's radiator support had factory duel or single headlights?
I like 1980 front end looks great into 1983 Truckin'
I'm looking for like your bucket seats with center fold console bench one is for my 1984 GMC with SWB but I can't afford to get a newer 2009 seats for her.  :-\
What year of Truck's bench seats will fits mine? I can afford to get one if under year 1997 full-sized Chevy Truck or Suburban? Let me know, thanks.  :)
1984 GMC Modified 2wd, swb, p/u with Hi Performance 355, 700R4, Stainless S. headers, 2.5" duel exhaust, 40 series Deltaflow mufflers, more custom. Check it out my baby Truckin' pics: http://s960.photobucket.com/albums/ae86/GMC_Truckin_NDN
Offline DFAA
« Reply #16 on: July 06, 2009, 08:31:08 pm »
Thanks GMC_,
I believe it was factory dual, though I may be wrong.
As far as bench seat, I honestly couldnt tell you. Maybe someone with a little more knowledge can answer that.
Dan
Offline oldwhity
« Reply #17 on: July 07, 2009, 07:38:20 pm »
Great looking truck. Interior looks awesome!
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline topnotchchevy
« Reply #18 on: July 08, 2009, 12:24:06 am »
I see you had a subwoofer in between the two seats before you put the new one.
What size was it? I would like to do the same to mines.
Offline DFAA
« Reply #19 on: July 08, 2009, 12:35:02 pm »
Thanks Oldwhity. Worked my ass off on that interior. Most of the work you cant even see, it has 2 layers of dynamat type sound deadening, plus liquid sound deadening on top of that. Solid.
Topnotch, I was able to keep the sub in there even after putting in the center seat/console. Its an Infinity Reference series 10in. sub.....
I really need to find a smaller box for it though(not so deep), the center seat sits a little farther forward than I would like.
Dan
« Reply #20 on: July 08, 2009, 11:54:31 pm »
Oh aight thanks. I had a 12 punch sub in mines but it didnt fit in between so i just had it in the passenger side. Your idea is good ima go for the 10 inch.
But did yours sound good when you had it in there?
Offline DFAA
« Reply #21 on: July 09, 2009, 01:14:24 am »
Yea, it sounds just fine, I will try to get a good pic of it behind the center console/seat.
I have 2 amps, one behind each seat, one for the highs/mids and one for the single sub.
Dan
Offline vsoree
« Reply #22 on: August 04, 2009, 09:54:25 pm »
truck looks good, I need your headliner, can i borrow it,lol.
Offline DFAA
« Reply #23 on: August 06, 2009, 01:22:17 am »
lol.....thanks
I finally got it legal and on the road, just passed the 500 mile mark and its time for another oil change. Aside from melting my positive bat. cable to a header(not pretty, could have easily blown the battery) the thing runs great.
Dan
« Last Edit: August 06, 2009, 01:25:28 am by DFAA »
Offline SUX2BU99
« Reply #24 on: August 13, 2009, 04:23:40 pm »
Man, lookin' great. Can you give a quick rundown how you put your buckets in there? I put buckets in mine but I'd like to know how others do it.
Offline DFAA
« Reply #25 on: August 20, 2009, 01:19:38 pm »
It wasnt too bad actually. As I have said, these are out of a 2006 Lincoln.
Drivers side:
Front left bracket only needed to bad cut a little, then bent down to about a 45 deg. angle.
Rear left required no modification.
Front right I cut and bent straight down, then made an L bracket from an old exhaust hanger (1/4 inch I suppose, maybe thicker)
Rear right was the most interesting. The factory bracket came off at a weird angle, like 45 degrees down AND out. I cut the bracket off(cut large rivets), and I found that if I flipped it around, it layed in the floorpan(where the floor drops down) almost perfectly. Then set the seat in, lined it up, and some small welds finished it off.
Passenger side was very much the same.
I had to drill 4 new holes in the floor for each seat and used several large washes plus lock washers underneath.
I would still like to reinforce the floor with something better than washers, but it works for now. I used aftermarket seat belts that are bolted in the factory reinforced holes.
So, other than minor(ish) bracket modifications, they sat in there pretty well. I didnt have to build new seat subframes or anything like that.
Dan
Offline 2502
« Reply #26 on: August 20, 2009, 04:26:42 pm »
what did you put on your dash? i have two dashes both are cracked all to crap, one has a plastic dash cover which i thought about scrapping and doing something to the dash pad.
Offline DFAA
« Reply #27 on: August 20, 2009, 05:45:37 pm »
Its just a plastic cover, cant think of the brand name off hand. And its painted with colorbond(BMW Black).
