Author Topic: questions about swaping diffs.  (Read 19181 times)
Offline screamin86
Re: questions about swaping diffs.
« Reply #15 on: August 16, 2009, 04:29:21 pm »
ok so basicly on the axle side the shocks basicly bolt together then the axle? i havent really looked at mine much to notice lol again thanks for this info its been helping greatly!!
86 ta:lm7 hot cam boltons
Offline Engineer
« Reply #16 on: August 16, 2009, 08:42:13 pm »
What you do is install the outboard shock into the axle bracket. The lower shock bolt will be about 5" long, and it will stick out through the bracket toward the inside of the truck. Install the spacer on the bolt, and then slide the bolt through the inboard shock. Install nut, and tighten.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline screamin86
« Reply #17 on: August 16, 2009, 08:50:15 pm »
ok cool that kinda what i was thinnking. now the fun part is gona be finding these parts at a decent price.
Offline maddog
« Reply #18 on: September 01, 2009, 09:32:41 am »
When looking for the Dana 60 don't always ask for Chevy/GMC Dodge also had the Dana 60 in there 3/4 -1 ton trucks and if you can find one for under 1,000 compleat you better get, most bone yards know what they have when it comes to these.
Offline joesgarage71
  • Wrench
« Reply #19 on: September 10, 2009, 08:05:51 pm »
Here are the pics that I promised:
Also visible in these photos is the Dana60 specific u-bolt plates
Should you buy a D60 and it not have the u-bolt plates, here are the OE part numbers for the plates:
DR: 370055
PA: 370056
These numbers have been discontinued by GM, but having the OE part number sometimes helps with a replacement parts search.
I have those same swaybar plates on a D-44 in old rusty.
