Author Topic: ignition wiring problem? truck wont do anything when the key is turned over  (Read 51124 times)
Offline ron350
Douellette have you tried adjusting the ignition switch yet.
1975 C10 step side stock with 350 two bbl. & 350 trans.
Offline Donut
ok i fixed the starter and its on now, but when i turn the key to start the parking brake light still turns on, i tried adjusting it and nothing, if i can how do i change it?
You won't get power to the starter if the neutral start switch is blocking it.  (brake light that comes on when you turn the key)  It would act like your trying to start it in gear.  Quick look for the obvious (burnt wire, wrong connections, etc) then start ruling out 1 thing at a time.  You've already changed out so much, I can't keep track.  Don't forget, new doesn't mean good.
I had an intermittent starting problem on my truck, it turned out to be a bad contact in the wiring pigtail on the column.  Only found by ruling out one thing at a time.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline gold84gmc
im getting power to the ignition switch but when i turn the key to start im not getting power...i tried using a jumper wire on the connector for the back up switch and it didnt change anything
92 buick century custom 3.3L
Offline gold84gmc
i just went to the parts store and got a new neutral safety backup switch, and the one they gave me is different than my old ones, the old ones just snapped into place(didnt have any screws) and they only have one spot for a connector to plug on....the new one uses screws to mount and has 4 different spots for connectors, and it doesnt fit my column
Offline gold84gmc
i feel like the biggest idiot now....i hooked up one of the other ignition switches but didnt mount it to the column and used a pick to move it to the different positions and moved it to start and it turned over....so i mounted it to the column and it didnt work again, thats when i remembered that it can be adjusted and i moved it closer to the steering wheel and it works now  ;D ;D ;D thanks for all the help and info
Glad to hear you got it. We all have chased ourselves at one time or another, so dont feel bad.
Offline Donut
Glad you got it. ;D
I've chased myself more times than I can count, usually 1 thing at a time works, and then it turns into a DUH moment as the problem is usually right in front of my face. ::)
If you hadn't gotten it by the end of the week, you were gonna get a PM to see if a fresh set of eyes could help.
« Last Edit: October 05, 2009, 06:11:27 pm by Donut »
350/tbh350/np205
Offline gold84gmc
haha ya just like when im looking for something and cant find it, then go back some other time and find it and it ended up being right out in the open, hate when that happens
